Disturbance in the transonic region using the PR_GAS fluid model |
June 16, 2022, 16:25 |
Hello !
I have been trying to run the NICFD nozzle case of the tutorials with CO2 instead of MDM, using the Peng-Robinson equation of state. However, I get some disturbance near the wall, that eventually cause the simulation to crash. I have run a few tests and this is what I was able to deduce: -The disturbance occurs when the flow is transonic/supersonic, not if the flow stays subsonic. -The disturbance does not appear when an Euler wall condition is imposed, but it appears when a heat-flux (no slip) condition is imposed. -It does not appear when using the ideal gas model. -It will appear either with a non structured mesh or a structured one. -It appears even if y+ < 1 -It will occur even at low CFL numbers (smaller than 1) when using the Euler implicit scheme. -It does not seem to occur when using the Euler explicit scheme, though I still have to make tests to be 100% sure. Has anyone experienced such kind of issue before? |
opaqueSolid radiation model in Fluid Region | dasith0001 | OpenFOAM Running, Solving & CFD | 1 | October 4, 2023 00:18 |
Multiphase heat transfer | pkladisios | CFX | 8 | June 7, 2016 01:41 |
Multiphase simulation of bubble rising | Niru | CFX | 5 | November 25, 2014 13:57 |
Setting rotating frame of referece. | RPFigueiredo | CFX | 3 | October 28, 2014 04:59 |
