April 25, 2022, 09:17 |
nspan Turbomachinery MPI issues
Madrid
Hello everyone,
I am a Master Student using SU2 for my msc thesis. I am trying as a first step to run a steady state simulation of a one row rotor stage using the turbomachinery tool. I am having an issue with the nspan of the outlet and looking for the fault on the forums I found that is maybe related to a partitioning error of the mpi capability, but when I tried running the simulation with one core, the fault remains happening. I also saw that the nspan can be manually specified somewhere but I dont know where. I attach a screenshot of the fault. Thank you in advance |
May 27, 2022, 10:57 |
Rep Power: 14 |
Hey there, probably there's something wrong with your mesh. Have you tried solving one of the test cases, a 3D centrifugal compressor case ? Probably that case will run at least without mpi.
May 28, 2022, 07:27 |
Madrid
Hi koray,
Thank you for your reply. Definitely it was a mesh issue, but I have not found where the mistake comes from yet. I have 3 volumes, all created with TurboGrid at the same time, and the first two volumes work fine but when I include the third one it crushes |
May 29, 2022, 05:25 |
Rep Power: 14 |
Can you share the image of the domains?
mpi error, nspan, turbomachinery cfd |
Issues on the simulation of high-speed compressible flow within turbomachinery | dowlee | OpenFOAM Running, Solving & CFD | 11 | August 6, 2021 07:40 |
MPI issues with my own solver | davide_c | OpenFOAM Running, Solving & CFD | 1 | March 23, 2012 09:57 |
Sgimpi | pere | OpenFOAM | 27 | September 24, 2011 08:57 |
Error using LaunderGibsonRSTM on SGI ALTIX 4700 | jaswi | OpenFOAM | 2 | April 29, 2008 11:54 |
Is Testsuite on the way or not | lakeat | OpenFOAM Installation | 6 | April 28, 2008 12:12 |
