Home > Forums > Software User Forums > SU2
Are the tutorial cases of NACA0012 up-to-date?
Old   April 12, 2022, 08:34
Question Are the tutorial cases of NACA0012 up-to-date?
Haolin Zhi
Haolin Zhi is on a distinguished road
Hi everyone,
I've been currently getting familiar with SU2 (version 7.3.1) according to the tutorial cases. I built up the solver from source code and there is not problem with the running of SU2.
Now the question is, I found the tutorial cases about unsteady flow (e.g., NACA0012 in compressible flow case and in shape optimization case) were written for version 7.0.1. I wonder whether there is big difference between version 7.0.1 and 7.0.3 (but they are both version 7....).
For example, the unsteady case of NACA0012, the time step presented on the website is 5e-3, while it is 5e-4 in the downloaded config file. I tried both the two time steps, and I cannot get the same aerodynamic history as presented on the website (the drag curve I derived is smooth and fluctuates near 0.22, while the website shows it is obviously periodical and fluctuates from 0.31 to 0.39). I didn't change any features in .cfg file except the time step.
For the case of unsteady discrete-adjoint optimization of NACA0012, there is the same difference of time step between the website and the .cfg file. When the SU2 runs this case, it always reports the error like "linear system orthogonality fails". I know the FGMRES diverges, but I didn't change the .cfg file.
So, I wonder, are the tutorial cases, especially for the unsteady ones, still usable for the SU2 version 7.3.1?
I really appreciate any help you could give me.
Kind regards,
Zhi
Haolin Zhi is offline   Reply With Quote
tutorial case, unsteady
[swak4Foam] difficulties installing swak4foam newbie29 OpenFOAM Community Contributions 120 October 21, 2022 05:01
[swak4Foam] Error: Installing swak4Foam into OpenFOAM 2.3.0 on CentOS 7 mushtime OpenFOAM Community Contributions 9 July 23, 2017 16:27
[swak4Foam] Problem with swak4Foam and OpenFOAM 2.3.1 behzad-cfd OpenFOAM Community Contributions 4 March 25, 2017 17:19
[swak4Foam] How to install swak4Foam in OF 2.3? preacher OpenFOAM Community Contributions 33 September 9, 2015 17:05
Errors running allwmake in OpenFOAM141dev with WM_COMPILE_OPTION%3ddebug unoder OpenFOAM Installation 11 January 30, 2008 21:30
