Home > Forums > Software User Forums > SU2
How to use FACE_FACE_MACH - seemingly does nothing
Old   April 6, 2022, 13:41
Default How to use FAN_FACE_MACH - seemingly does nothing
Tim
davistib is on a distinguished road
I'm trying to use the ENGINE_INFLOW_TYPE boundary conditions, without much luck.
The FAN_FACE_MACH and FAN_FACE_MDOT seem to do nothing, as in no BC gets applied (or it defaults to something else under to hood?).
FAN_FACE_PRESSURE seems to work as expected, but I don't know what the difference between that and just MARKER_OUTLET is, the behavior seems identical.
Specifics:
Simulating an inlet in supersonic flow. The freestream Mach is 1.64 and I have the inlet internals initialized as subsonic Mach 0.5 using the SUBSONIC_ENGINE_CYL options.
I'm initially running the inlet outflow (AIP) using the BC MARKER_OUTLET = ( AIP, <pressure> ), which works fine.
Ideally I'd like to specify an average Mach at the AIP, or a constant mass flow, for design simulations. I tried using the MARKER_ENGINE_INFLOW boundary conditions like
ENGINE_INFLOW_TYPE= FAN_FACE_MACH
MARKER_ENGINE_INFLOW = ( AIP, <aip_mach> )
or
ENGINE_INFLOW_TYPE= FAN_FACE_MDOT
MARKER_ENGINE_INFLOW = ( AIP, <aip_mdot> )
but nothing is happening.. it looks like the BC defaults to a characteristic outflow or something and there is no sensitivity to the solution to any value specified for <aip_mach> or <aip_mdot>.
If, however, I use
ENGINE_INFLOW_TYPE= FAN_FACE_PRESSURE
MARKER_ENGINE_INFLOW = ( AIP, <aip_pressure> )
Then the solution matches identically the result of using MARKER_OUTLET = ( AIP, <aip_pressure> )
davistib is offline   Reply With Quote
seemingly converged solution changes after restart achat FLUENT 2 September 3, 2018 04:55
Laminar model solves seemingly turbulent flow nmartin9319 Main CFD Forum 4 August 10, 2018 12:33
[ICEM] Quest for seemingly simple Blocking (degenerate block) la7low ANSYS Meshing & Geometry 0 July 12, 2011 20:48
