Segmentation fault when computing far-field noise |
March 21, 2022, 04:30 |
Martin ACCOU
Hello everyone,
I am using the version 7.1.1 "Blackbird" of SU2. When computing far field Noise of my surface files, I have the following Segmentation fault : Three dimensional problem. 11353 grid points. 57576 volume elements. 2 surface markers. 3970 boundary elements in index 0 (Marker = pff). 3824 boundary elements in index 1 (Marker = wall1). 57576 tetrahedra. Recomputing point connectivity. Setting element connectivity. Identifying edges and vertices. Computing centers of gravity. Setting the control volume structure. Volume of the computational grid: 798.455. Storing a mapping from global to local point index. ------------------------- Solution Postprocessing ----------------------- ------------------------- Computing Far Field Noise ----------------------- iZone: 0 and nZone: 1 Reading header from surface_flow_00001.dat, number of surface nodes: 3838 Reading Tecplot surface file surface_flow_00001.dat Reading Tecplot surface file surface_flow_00501.dat Segmentation fault (core dumped) I have tried on other test cases and I have the same problem. Does anyone would have an idea how to solve my problem? Thanks ! |
parallel run in foam extend | CRI_CFD | OpenFOAM CC Toolkits for Fluid-Structure Interaction | 5 | March 28, 2024 08:36 |
Segmentation fault (core dumped) | NH1994 | OpenFOAM Programming & Development | 0 | January 9, 2015 01:24 |
Moving mesh | Niklas Wikstrom (Wikstrom) | OpenFOAM Running, Solving & CFD | 122 | June 15, 2014 06:20 |
Segmentation fault with parallel computing | Prad | Main CFD Forum | 0 | December 11, 2008 07:44 |
Near field noise prediction | Usman | CFX | 1 | January 23, 2008 11:15 |
