CST parameterization method in SU2 for dimensionality reduction |
March 10, 2022, 03:42 |
Binglin Wang
Hi all,
Thanks for reading my question. In su2 optimization, I am facing the problem of high parameter dimension. For example, Unconstrained shape design of a transonic inviscid airfoil at a cte. AoA (https://su2code.github.io/tutorials/...ined_NACA0012/), the number of parameters has reached 38, and the Aerodynamic Shape parameterization method is the Hicks Henn method. In the optimization algorithm I designed, the dimension should be less than 20. After reading the literature, the CST parameterization method can be used for dimensionality reduction, but I don't see that SU2 provides an option for CST. Although it exists in tools.py, it doesn't actually work. Does anyone know how to implement the CST method, or use other methods to achieve dimensionality reduction? Thanks all the best. Yours, Binglin |
cst, design, optimization |
On the alpha Eqn of VOF method when using Immersed boundary method in OpenFOAM | keepfit | OpenFOAM | 4 | January 31, 2014 15:32 |
interFoam and Continuous-Species-Transfer (CST) method | kel85uk | OpenFOAM | 2 | December 22, 2012 20:05 |
[Gmsh] discretizer - gmshToFoam | Andyjoe | OpenFOAM Meshing & Mesh Conversion | 13 | March 14, 2012 05:35 |
interFoam and Continuous-Species-Transfer (CST) method | kel85uk | OpenFOAM Programming & Development | 0 | May 3, 2011 05:16 |
Code for most powerfull FDV Method | D.S.Nasan | Main CFD Forum | 6 | September 4, 2008 03:08 |
