February 24, 2022, 05:32 |
openvsp geometry to volume mesh for SU2
Rep Power: 6 |
Dear Colleagues
openvsp software is useful for creating geometry Is there an easy way to transform the geometry to SU2 volume mesh file (including farfield, symmetry plane (or not) ). Any help, hints welcome Many thanks rn86j |
February 24, 2022, 13:56 |
bigfoot
Rep Power: 21 |
You can export the mesh to stl and import it in gmsh and then export to su2 from there. You can add the boundary conditions in gmsh as well
March 8, 2022, 11:43 |
#3 | |
Rep Power: 6 |
I merged an STL file. But the resulting grid in the outer volume seems to go through the object from the STL file.... Must be doing some commands incorrectly! Will it be possible to jot down the sequence of commands needed or perhaps a geo or ? I am trying to create a Spherical volume grid around a simple wing (or wing-body) stl file Many Thanks and help appreciated rn86j |
[ICEM] Volume Meshing Problem; YOUR GEOMETRY HAS A HOLE | mariachi | ANSYS Meshing & Geometry | 5 | May 30, 2018 03:52 |
Problem of simulating of small droplet with radius of 2mm | liguifan | OpenFOAM Running, Solving & CFD | 5 | June 3, 2014 03:53 |
[ICEM] Generating Mesh for STL Car in Windtunnel Simulation | tommymoose | ANSYS Meshing & Geometry | 48 | April 15, 2013 05:24 |
On the damBreak4phaseFine cases | paean | OpenFOAM Running, Solving & CFD | 0 | November 14, 2008 22:14 |
How to control Minximum mesh space? | hung | FLUENT | 7 | April 18, 2005 10:38 |
