Empty HISTORY file - TURBOMACHINERY simulation |
January 11, 2022, 10:34 |
#1 | ||
Nicola Fontana
Rep Power: 4 |
I am running a turbomachinery simulation of a stator blade, everything seems fine and the simulation arrives at the end and says "Exit success". When the program is running I can see the residual
This issue happens only with the TURBOMACHINERY mode. I tried to add in the configuration file the option Code:
HISTORY_OUTPUT = RMS_DENSITY Version: 7.2.0 "Blackbird", with Windows 10. Configuration file attahced. Thank you in advace, Nicola Last edited by Nicola_Fontana; January 11, 2022 at 11:43. |
January 15, 2022, 03:02 |
PENG YAN
Rep Power: 5 |
From my side, if you run turbo machine, the output file will be written in a file, whose name is 'history', rather than 'history.csv'.
You can try to check that file. |
[Other] Tabulated thermophysicalProperties library | chriss85 | OpenFOAM Community Contributions | 62 | October 2, 2022 03:50 |
polynomial BC | srv537 | OpenFOAM Pre-Processing | 4 | December 3, 2016 09:07 |
[swak4Foam] swak4foam building problem | GGerber | OpenFOAM Community Contributions | 54 | April 24, 2015 16:02 |
Problem compiling a custom Lagrangian library | brbbhatti | OpenFOAM Programming & Development | 2 | July 7, 2014 11:32 |
[swak4Foam] build problem swak4Foam OF 2.2.0 | mcathela | OpenFOAM Community Contributions | 14 | April 23, 2013 13:59 |
