January 10, 2022, 12:01 |
SU2 history.dat files not opening in Tecplot
Josh Kelly
Rep Power: 8 |
I'm fairly new to SU2 so apologies if this is a fairly trivial question. I'm running an unsteady simulation based upon the APU turbocharger test case and my simulation diverges. I want to check the convergence history in tecplot using the history .dat files but they don't open in tecplot, I get the error unexpected end of file after location I,J,K var = 55,1,1,17 tecplot This occurs with a history.dat file of a completed simulation also, can anyone help? I have attached my .cfg file for reference. Thank you in advance |
January 11, 2022, 08:29 |
Rep Power: 13 |
could you please attach the history file? In the meanwhile, you can use gnuplot to see the convergence. |
January 11, 2022, 09:35 |
Josh Kelly
Rep Power: 8 |
Here's the history.dat file for both zones
January 11, 2022, 10:36 |
Rep Power: 13 |
The header of tecplot files lists 72 variables (line 2), while the written data are 71. I don't know which data is missing, but you can open the file with tecplot by deleting, for example, the string "Time(min)".
SU2 crashes while generating output files | BenP | SU2 | 3 | August 21, 2019 04:24 |
tecplot: read UDM variables from fluent data files | denis.sanga@hotmail.it | FLUENT | 0 | July 24, 2018 06:40 |
[General] Time series and animations for tecplot files | Ivan | ParaView | 1 | August 21, 2013 13:15 |
[General] Importing 1D Tecplot files to Paraview with Zones results in NA | weirdtunguska | ParaView | 2 | July 18, 2013 12:01 |
Results saving in CFD | hawk | Main CFD Forum | 16 | July 21, 2005 21:51 |
