January 8, 2022, 02:23 |
SU2 v7.2.1 - Wrong number of OUTPUT_WRT_FREQ
pro
Rep Power: 6 |
I have the following configuration file
% ------------- DIRECT, ADJOINT, AND LINEARIZED PROBLEM DEFINITION ------------% SOLVER = EULER SYSTEM_MEASUREMENTS = SI WRT_BINARY_RESTART = YES % ------------------------ Time-dependent Simulation --------------------------% TIME_DOMAIN = YES TIME_STEP = 0.0017453292519943296 MAX_TIME = 0.005235987755982989 INNER_ITER = 251 TIME_ITER = 3 MACH_NUMBER = 0.8 MACH_MOTION = 0.8 % -------------------- COMPRESSIBLE FREE-STREAM DEFINITION --------------------% AOA = 0.0 FREESTREAM_PRESSURE = 101325.0 FREESTREAM_TEMPERATURE = 985.7982827277253 % ---------------------- REFERENCE VALUE DEFINITION ---------------------------% REF_ORIGIN_MOMENT_X = -0.5 REF_ORIGIN_MOMENT_Y = 0.0 REF_ORIGIN_MOMENT_Z = 0.0 REF_LENGTH = 1.0 REF_AREA = 1.0 REF_DIMENSIONALIZATION = DIMENSIONAL % ----------------------- DYNAMIC MESH DEFINITION -----------------------------% GRID_MOVEMENT = RIGID_MOTION PITCHING_OMEGA = 0.0 0.0 100.0 PITCHING_AMPL = 0.0 0.0 1.0 MOTION_ORIGIN = -0.5 0.0 0.0 % -------------------- BOUNDARY CONDITION DEFINITION --------------------------% MARKER_EULER = (airfoil) MARKER_FAR = (farfield) % ------------------------ SURFACES IDENTIFICATION ----------------------------% MARKER_PLOTTING = (airfoil) MARKER_MONITORING = (airfoil) % ------------------------ LINEAR SOLVER DEFINITION ---------------------------% LINEAR_SOLVER = FGMRES LINEAR_SOLVER_PREC = LU_SGS LINEAR_SOLVER_ERROR = 0.0001 LINEAR_SOLVER_ITER = 2 % -------------------------- MULTIGRID PARAMETERS -----------------------------% MGLEVEL = 3 MGCYCLE = W_CYCLE MG_PRE_SMOOTH = (1, 2, 3, 3) MG_POST_SMOOTH = (0, 0, 0, 0) MG_CORRECTION_SMOOTH = (0, 0, 0, 0) MG_DAMP_RESTRICTION = 0.75 MG_DAMP_PROLONGATION = 0.75 % ----------------------- NUMERICAL METHOD DEFINITION -------------------------% NUM_METHOD_GRAD = WEIGHTED_LEAST_SQUARES CFL_NUMBER = 10.0 CONV_NUM_METHOD_FLOW = JST MUSCL_FLOW = YES SLOPE_LIMITER_FLOW = VENKATAKRISHNAN ENTROPY_FIX_COEFF = 0.001 JST_SENSOR_COEFF = (0.5, 0.02) TIME_DISCRE_FLOW = EULER_IMPLICIT % ------------------------ GRID DEFORMATION PARAMETERS ------------------------% DEFORM_LINEAR_SOLVER = FGMRES DEFORM_LINEAR_SOLVER_PREC = LU_SGS DEFORM_LINEAR_SOLVER_ITER = 500 DEFORM_STIFFNESS_TYPE = INVERSE_VOLUME % --------------------------- CONVERGENCE PARAMETERS --------------------------% CONV_CRITERIA = RESIDUAL CONV_RESIDUAL_MINVAL = -8 CONV_STARTITER = 0 CONV_CAUCHY_ELEMS = 100 CONV_CAUCHY_EPS = 1e-10 % ------------------------- INPUT/OUTPUT INFORMATION --------------------------% MESH_FILENAME = mesh.su2 MESH_FORMAT = SU2 SOLUTION_FILENAME = solution.dat TABULAR_FORMAT = CSV CONV_FILENAME = history RESTART_FILENAME = solution.dat VOLUME_FILENAME = volume SURFACE_FILENAME = surface OUTPUT_WRT_FREQ = 1 SCREEN_OUTPUT = (TIME_ITER,INNER_ITER,RMS_DENSITY,RMS_ENERGY,LIFT,DRAG_ON_SURFACE) HISTORY_OUTPUT = (ITER,RMS_RES,AERO_COEFF,TIME_DOMAIN,WALL_TIME) HISTORY_WRT_FREQ_INNER = 1 HISTORY_WRT_FREQ_OUTER = 1 HISTORY_WRT_FREQ_TIME = 1 SCREEN_WRT_FREQ_INNER = 1 SCREEN_WRT_FREQ_OUTER = 1 SCREEN_WRT_FREQ_TIME = 1 OUTPUT_FILES = (RESTART) Ill be running a DUAL_TIME_STEP simulation after this simulation, so i would need solution_00000.dat. Any ideas as to why this is happening? EDIT: SOLVED I forgot to add TIME_MARCHING= DUAL_TIME_STEPPING-2ND_ORDER |
[mesh manipulation] Mesh Refinement | Luiz Eduardo Bittencourt Sampaio (Sampaio) | OpenFOAM Meshing & Mesh Conversion | 42 | January 8, 2017 12:55 |
udf error | srihari | FLUENT | 1 | October 31, 2016 14:18 |
[mesh manipulation] Importing Multiple Meshes | thomasnwalshiii | OpenFOAM Meshing & Mesh Conversion | 18 | December 19, 2015 18:57 |
[blockMesh] BlockMeshmergePatchPairs | hjasak | OpenFOAM Meshing & Mesh Conversion | 11 | August 15, 2008 07:36 |
[Commercial meshers] Trimmed cell and embedded refinement mesh conversion issues | michele | OpenFOAM Meshing & Mesh Conversion | 2 | July 15, 2005 04:15 |
