Shahid Khan
Rep Power: 4 ![]() |
I want to know which turbulence models are available in SU2? Are only SST and SA and its derivatives available? What about k-w or k-epsilon models and others?
Roland
Rep Power: 0 ![]() |
The list of turbulence models available can be found in config_template.cfg
Have a look there and maybe you will find something you're looking for. Not much of a choice there though.
skipgroup.pl |
Shahid Khan
All the available models are available in template configuration file or only some of them are written there as a reference?
bigfoot
Rep Power: 17 ![]() |
All models are mentioned in config_template.cfg. Basically SA and SST models. SST is a k-omega model. k-epsilon is a historical model that is still much used because of it's robustness but it does not offer better results compared to SST.
There are also DES and LES models available if RANS is not sufficient and if you have the computational power available. |
Shahid Khan
Thanks. I got it.
Adding turbulence models to (reacting)TwoPhaseEulerFoam | lavdwall | OpenFOAM Running, Solving & CFD | 0 | February 3, 2017 03:04 |
y+ range for turbulence models | babri | FLUENT | 1 | August 30, 2016 17:39 |
in k-epsilon wall function approach high Re turbulence models: question of velocity | romant | OpenFOAM Programming & Development | 6 | May 26, 2016 09:14 |
Advice about turbulence models? | mqsim | OpenFOAM Running, Solving & CFD | 6 | April 27, 2016 07:50 |
Only two turbulence options available in CFX Pre | Jack001 | CFX | 5 | March 30, 2016 02:47 |
