Cauchy convergence criteria for Cmx, Cmy or Cmz? |
December 14, 2021, 12:42 |
Arne Voß
Rep Power: 5 |
Hi everyone,
is it possible to use e.g. the rolling, pitching and/or yawing moment coefficients to determine cauchy convergence? Example: I believe that this would be useful to determine a converged solution for e.g. an aileron deflection, which doesn't change the lift coefficient very much but should be clearly visible in the rolling moment. After reading the documentation, I tried to set: CONV_FIELD= ( LIFT, MOMENT-X, MOMENT-Y ) in the config file, but I see the following messages: Ignoring Convergence Field(s): MOMENT-X MOMENT-Y Convergence field(s): LIFT Where is my mistake?? |
December 14, 2021, 15:28 |
Pedro Gomes
Rep Power: 14 |
I think they are written with underscore instead of -
December 15, 2021, 06:24 |
Arne Voß
Rep Power: 5 |
Hi Pedro,
thank you very much for the quick reply. Could you please update the documentation? https://su2code.github.io/docs_v7/Custom-Output/ MOMENT-X Total Moment around the x-axis. MOMENT-Y Total Moment around the y-axis. [...] However, i have a follow-up question. I believe it would be helpful if the user can choose between relative or absolute values for cauchy convergence. Example: For the clean aircraft, the rolling moment coefficient MOMENT_X is close to zero and thus will never reach a relative cauchy convergence ->> dividing tiny numbers is not a good idea. Using absolute cauchy convergence is more robust in this case. Arne |
December 15, 2021, 07:21 |
Pedro Gomes
Rep Power: 14 |
Happy to help Arne.
If you could open a PR to update the docs it would be great https://github.com/su2code/su2code.github.io That is a good point, maybe we can switch automatically to absolute if the value of the monitored quantity is below 1, or add a custom scaling factor, that when set in the config overrides the behavior of dividing by the absolute value of the quantity. |
December 15, 2021, 08:05 |
Arne Voß
Rep Power: 5 |
Hi Pedro,
I corrected the documentation and created a pull request. Because this is the first time for me, I am not sure if I did this correctly? I would suggest to have something like: CONV_CAUCHY_TOTAL = CONV_CAUCHY_ABS + CONV_CAUCHY_RELATIVE. In this way, the user could set CONV_CAUCHY_ABS=0.0 if he or she wanted to use only relative convergence or set CONV_CAUCHY_RELATIVE=0.0 to use only absolute convergence. Also, I would suggest individual parameters for each physical value similar to this: CONV_FIELD= ( LIFT, DRAG, MOMENT_Y ) CONV_CAUCHY_ABS= ( 1E-4, 1E-5, 1E-4) CONV_CAUCHY_RELATIVE = (0.0, 0.0, 0.0) |
December 15, 2021, 18:16 |
Pedro Gomes
Rep Power: 14 |
Thank you for the PR!
I see how that would work but unfortunately, it would not be a backward compatible change, and I think the relative + absolute logic would confuse folks. Whatever we introduce must be simple and inactive by default to keep backward compatibility. |
OpenFoam programming new convergence criteria | m_zanichelli | OpenFOAM Programming & Development | 2 | August 11, 2021 05:06 |
Time step size & convergence absolute criteria | yuitsang | FLUENT | 5 | April 15, 2013 05:27 |
Convergence criteria | PrandtlGlawert | Main CFD Forum | 1 | August 13, 2009 18:13 |
Convergence of CFX field in FSI analysis | nasdak | CFX | 2 | June 29, 2009 02:17 |
convergence criteria | mujahid | FLUENT | 7 | March 6, 2004 16:06 |
