November 23, 2021, 12:40 |
Problem with RAE optimization tutorial
Andrea Michelotti
Rep Power: 5 |
Hello everyone,
I am trying to run the RAE optimization tutorial without the solution_adj_cd.dat and solution_adj_cmz.dat files because I have to optimize different configurations but the process ends after the DIRECT solution because those file are not present. I tried to run each step of the optimization process individually but I reached the same problem. After running the DIRECT problem, I used the restart file as the solution one for the CONTINUOUS_ADJOINT problem but I received the same message: Code:
Error in "void CSolver::Read_SU2_Restart_Binary(CGeometry*, const CConfig*, std::__cxx11::string)": ------------------------------------------------------------------------- Unable to open SU2 restart file solution_adj_cd.dat I can't figure out why I can't bypass those files or how to generate new ones because even with RESTART_SOL=NO and/or running the process step by step I face the same message. Does anyone know what I am missing? I attach my config files and the tutorial one. Thank you in advance |
November 23, 2021, 12:47 |
Pedro Gomes
Rep Power: 13 |
Can you try reproducing those files for your new configuration? i.e. run SU2_CFD directly with MATH_PROBLEM=CONTINUOUS_ADJOINT for your initial design.
November 23, 2021, 13:18 |
Andrea Michelotti
Rep Power: 5 |
Hi!
The file RAE2822_8_1_1_600_350.cfg is the one I am using for both inviscid and viscous flow with the appropriate changes. I use shape_optimization.py to run the process. In the inviscid case the optimization runs fine, for the viscous it doesn't because it requires the soluiton_adjoint files. I also tried, just in case, to change the profile with the NACA0012 as in the previous tutorial but the RANS simulation gives the same message. I copy here the .su2 mesh so it is possible to run the case. https://drive.google.com/file/d/1qDj...ew?usp=sharing |
November 26, 2021, 04:37 |
Andrea Michelotti
Rep Power: 5 |
I have tried to run again the viscous cfg file for both my case study and the tutorial with MATH_PROBLEM=DIRECT and after that MATH_PROBLEM=CONTINUOUS_ADJOINT with and without RESTART_SOL option and in every case I received the message:
Error in "void CSolver::Read_SU2_Restart_Binary(CGeometry*, const CConfig*, std::__cxx11::string)": ------------------------------------------------------------------------- Unable to open SU2 restart file RAE2822_8_1_1_600_350_restart_adj_cd.dat After that, I have run the CONTINUOUS_ADJOINT problem for the RANS case and it seems to work because the restart_adj_cd.dat file now exists. Also, it seems to converge to a solution. I don't think it is a feasable one. I found that the RESTART_SOL seems not to work because the program continues to search for the RESTART_ADJ_FILENAME_cd.dat even thought RESTART_SOL=NO. I don't know what to do because I don't get why this is happening. Another viscous optimization case study is the Unsteady NACA0012 one which doesn't require the RESTART_ADJ_FILENAME_cd.dat files as initial solution for the problem. I have tried to find discrepancies but I did not find anything. I even tried to run the TestCases/optimization_rans/steady_oneram6 and I receive the same message. No one has ever experienced this problem before? |
December 23, 2021, 19:01 |
zhou
Rep Power: 7 |
I encountered the same problem. I tried 'cont_adj_rans' of TestCase, but the problem also occured. Is resrart file necessary for continuous adjoint based on RANS?
adjoint, rae, shape_optimization, tutorial |
CFD Fluent tutorial - Shell and tube heat exchanger - PROBLEM | tom96 | FLUENT | 1 | May 21, 2018 00:24 |
multiRegionHeater tutorial visualization problem | Bufacchi | OpenFOAM Running, Solving & CFD | 3 | September 18, 2015 09:20 |
Problem on Fluent Tutorial: Horizontal Film Boilig | Feng | FLUENT | 2 | April 13, 2013 05:34 |
newbie problem with cavity tutorial | miki | OpenFOAM Running, Solving & CFD | 8 | September 2, 2012 15:22 |
Help! Compiled UDF problem 4 Wave tank tutorial | Shane | FLUENT | 1 | September 3, 2010 02:32 |
