Home > Forums > Software User Forums > SU2
SU2 Unsteady NACA0012 Tutorial case
Old   November 22, 2021, 14:10
Post SU2 Unsteady NACA0012 Tutorial case
Guangnan Jia
Gj419 is on a distinguished road
Hello, Everyone.
Currently, I'm learning to perform unsteady simulation on SU2. I run successfully with the SU2 given tutorial unsteady NACA0012 case in compressible part. However, that case is the one which two restart file are given to performing the unsteady simulation. My question is that how to run the this unsteady case without pre-given restart file. I have tried RESTART_SOL = NO , but the results from this simulation is totally different with the given results as shown in the SU2 website. Specifically, there is no lift or drag coefficient periodic oscillation with time iteration. Can anyone tell me the normal process for performing general unsteady simulation in SU2 and take this SU2 tutorial NACA-0012 case as an example to explain. Thanks very much.
Gj419 is offline   Reply With Quote
Old   November 23, 2021, 12:55
Andrea Michelotti
AndreaMichelotti is on a distinguished road
sadly I can't help you because I am facing the same problem with the RAE constrained optimization tutorial.
I use the same cfg file for both inviscid and viscous flow changing the mesh accordingly but in the first case the optimization runs fine without any external initialization file while the latter stops with the error:
Error in "void CSolver::Read_SU2_Restart_Binary(CGeometry*, const CConfig*, std::__cxx11::string)":
Unable to open SU2 restart file RAE2822_solution_adj_cd.dat
This file is generated directly within the optimization but in the viscous case it doesn't and it must be given as can be seen running the tutorial without the external files.
I saw that the unsteady tutorial in the design page doesn't require the restart file.
AndreaMichelotti is offline   Reply With Quote
Turbulent flow over NACA0012 airfoil validation case (openfoam.com) Luke_M OpenFOAM Running, Solving & CFD 1 July 5, 2021 19:45
Cavity tutorial case shinde.gopal OpenFOAM Running, Solving & CFD 3 June 12, 2015 06:50
Steady or Unsteady Case aqib FLUENT 0 December 22, 2010 02:55
how to predict unsteady flow from case definition? Felix Main CFD Forum 6 August 28, 2007 17:40
Free surface boudary conditions with SOLA-VOF Fan Main CFD Forum 10 September 9, 2006 13:24
