charan
Rep Power: 5 ![]() |
Hi everyone,
i am very new to SU2. i have used fluent earlier, in which we have an option to monitor continuity & velocities across each iteration. In SU2 i came across history file which writes out RMS Rho. Is this the same as the continuity which we monitor in fluent? if not , is there any other way to monitor continuity?.. thank you for spending time in reading my question with regards charan |
Akshay Koodly
Rep Power: 9 ![]() |
Yes, the RMS Rho is the residual of the continuity equation for the compressible solver. In case you are using the incompressible solver, the RMS of pressure acts as a proxy for the continuity equation. Cheers, Akshay |
charan
thank you for your reply. it would be very helpful if you can point me to any literature of the same thing which i can include in my work as a reference.
na
Rep Power: 8 ![]() |
Please see this https://arc.aiaa.org/doi/abs/10.2514/1.J058222 for a little background. See whether this fits your needs.
The inc solver was implemented by Thomas Economon and he wrote this paper about it Best, Tobi |
charan
HI Tobi,
thank you so much, the pdf shared by you gave me an insight of incompressible solver. Cheers, Charan |
Setting the height of the stream in the free channel | kevinmccartin | CFX | 12 | October 13, 2022 21:43 |
pimpleDyMFoam computation randomly stops | babapeti | OpenFOAM Running, Solving & CFD | 5 | January 24, 2018 05:28 |
Convergence moving mesh | lr103476 | OpenFOAM Running, Solving & CFD | 30 | November 19, 2007 14:09 |
IcoFoam parallel woes | msrinath80 | OpenFOAM Running, Solving & CFD | 9 | July 22, 2007 02:58 |
Poisson equation vs continuity equation | DJ | Main CFD Forum | 1 | August 5, 2004 20:01 |
