October 9, 2021, 16:30 |
Newly installed SU2 issues running testcases
Sunil
Hello
I have just installed and compiled the SU2 source code and have come into issues when I have tried to run a test case. I have tried running multiple test cases and I am getting the same issue the error message has been coppied below. I am new to SU2 and would appreciate some help Error in "void CConfig::SetConfig_Parsing(std::istream&)": ------------------------------------------------------------------------- Line 108 EXT_ITER: invalid option name. Check current SU2 options in config_template.cfg. Did you mean EXT_ITER_OFFSET? ------------------------------ Error Exit ------------------------------- -------------------------------------------------------------------------- MPI_ABORT was invoked on rank 0 in communicator MPI_COMM_WORLD with errorcode 1. NOTE: invoking MPI_ABORT causes Open MPI to kill all MPI processes. You may or may not see output from other processes, depending on exactly when Open MPI kills them. Sunil |
October 11, 2021, 21:54 |
Wally Maier
Rep Power: 7 |
Hi Sunil,
What test cases are you running? That config option is out-of-date with the most recent release of SU2. Wally |
October 14, 2021, 03:41 |
Sunil
Hi Wally
I am running the transition flat plate test cases that have come with the installation I cant get any test case to run. I have followed the compile instructions exactly but can not get SU2 to run Sunil |
October 14, 2021, 11:57 |
na
Rep Power: 8 |
unfortunately we have some cases in the Testcases/ folder that are not in our automatically tested regression tests. So that folder name is maybe a bit misleading ... or just needs thorough cleaning. Please exchange the EXT_ITER with ITER or INNER_ITER, in case of steady single-zone cases (as it the case here) the two options are identical. best, tobi |
instalation, su2, testcases |
Issues when using multi-processor parallel computation in SU2 | Xiaosong | SU2 | 4 | February 16, 2016 15:55 |
Multigrid Stability Issues | ThomasHermann | SU2 | 1 | November 5, 2014 17:18 |
SU2 Tutorial 2 Parallel Computation | CrashLaker | SU2 | 7 | April 5, 2014 17:14 |
Issues running custom code in parallel | BigBlueDart | OpenFOAM Programming & Development | 4 | October 23, 2013 07:17 |
Issues with running in parallel OF-2.2.0 | kalyangoparaju | OpenFOAM | 0 | June 21, 2013 13:41 |
