September 28, 2021, 16:01 |
Transpiration b.c.
CA-AB
Hi. New to SU2. Trying to model bleed and blowing, and wanted to use the transpiration boundary condition. How do you do this in SU2? Assume specific marker for the boundary/wall in the cfg file, but what is the exact command and arguments. Searched around github, but can't find anything with the transpiration implementation details. Thx.
September 29, 2021, 08:39 |
na
Rep Power: 8 |
I have to admit I am not sure what a transpiration BC is. If you could quickly explain or give a reference to what you have in mind that would help. Also in which context are you using that. Searching through the code-base revealed no hits for "transpiration" and I also never saw that. So I guess it is not present. But it is usually not too difficult to code up a boundary condition yourself. If you are interested in doing that please let me know. Best, Tobi |
September 29, 2021, 18:28 |
bigfoot
Rep Power: 21 |
I guess you mean a (semi) permeable or porous wall, where a certain amount of flow passes through the wall, either naturally or forced. This would mean either having a wall with a nonzero normal velocity or some modified surface velocity gradient based on Darcy's law. In any case we do not have such a boundary condition right now. As Tobi said, if you can be more specific then we can help you . |
October 20, 2021, 13:27 |
CA-AB
Yes. I mean permeable wall b.c. to pass mass flow across the surface wall. For example, mass out from wall (remove from flow surface) to simulate bleed/suction (i.e. to remove low momentum boundary layer).
November 26, 2021, 13:16 |
Davide Gatti
Rep Power: 10 |
Hi, have you made any progress with the new boundary condition? I am planning to do the same but I have not been very successful yes. I was trying to make a kind of merge between the Inlet/Outlet and the constant temperature wall boundary condition. I have not really been succesfull at the moment. As a test case for testing the effect of the BC I am using the laminar compressible boundary layer.
[extend-bazaar] How to apply timeVaryingSolidTraction B.C. to fsiFoam? | postechkian | OpenFOAM Programming & Development | 1 | April 8, 2019 05:25 |
B.C. of buoyantSimpleFoam for external flow | mit326 | OpenFOAM Running, Solving & CFD | 0 | August 23, 2018 04:18 |
[ICEM] setting B.C & FF shape for high A.O.A. | jyh3134 | ANSYS Meshing & Geometry | 5 | August 7, 2013 04:23 |
Urgent! Help on UDF to set B.C. of 3rd type | Ray Hong | FLUENT | 0 | December 28, 2005 20:35 |
How to set B.C. of the 2nd or 3rd type in UDS? | Ray Hong | FLUENT | 0 | December 28, 2005 07:03 |
