September 18, 2021, 02:47 |
custom boundary conditions in SU2
NDP
Rep Power: 5 |
I am trying to add custom boundary conditions for my CFD analysis in which i have to provide dritchlet B.C. on a marker using a text file having variable values stored. I tried to add my own BC_custom code but it seems its not working. Plz help me regarding implementation of BC_Custom
September 18, 2021, 14:29 |
bigfoot
Rep Power: 21 |
Do you mean you would like to use the option SPECIFIED_INLET_PROFILE= YES ? We have a number of testcases here, split into config files and meshes : https://github.com/su2code/TestCases https://github.com/su2code/SU2/tree/master/TestCases An example using an inlet profile is here: https://github.com/su2code/SU2/blob/...poiseuille.cfg if the file containing the inlet profile does not exist yet, SU2 will create a default file for you and exit. You can then edit this file. |
October 6, 2021, 14:35 |
BC_Custom
NDP
Rep Power: 5 |
No I am talking about providing the solution for a boundary marker as custom boundary condition. I have made some changes in the else condition of BC_custom function of CFVMFlowSolverBase.inl , but still i am not getting the correct solution.
code which i have written in th else condition unsigned short iVar; unsigned long iVertex, iPoint, total_index, iLine, iBnd; bool fndBnd; /*--- Identify the boundary by string name ---*/ string Marker_Tag = config->GetMarker_All_TagBound(val_marker); cout<<"marker name"<<Marker_Tag<<endl; unsigned long bc_dat_point[geometry->nVertex[val_marker]]; double bc_dat[geometry->nVertex[val_marker]][nVar]; int rank = MASTER_NODE; //Expect custom b.c. data in an ASCII file with filename same as the marker //and extension ".txt" char bc_filename[MAX_STRING_SIZE]; strcpy(bc_filename, (Marker_Tag+".txt").c_str()); ifstream bc_file; bc_file.open(bc_filename, ios::in); if (bc_file.fail()) { if (rank == MASTER_NODE) cout << endl << "Custom bc file (" << bc_filename << ") missing!" << endl; exit(EXIT_FAILURE); } string text_line; /*--- Parse the custom bc data file ---*/ //It is a space-delimited ASCII file, with each line corresponding to a //boundary point; in each line, the first entry is the point index (w.r.t. the //global mesh), and the remaining entries are the solution values at the point getline (bc_file, text_line); stringstream linestream1(text_line); int nVertFile, nVarFile; linestream1 >> nVertFile >> nVarFile; if (nVertFile != geometry->nVertex[val_marker]) { cout << "Mismatch of no. of vertices in custom bc file " << nVertFile << endl; exit(EXIT_FAILURE); } if (nVarFile != nVar) { cout << "Mismatch of no. of variables in custom bc file " << nVarFile << endl; exit(EXIT_FAILURE); } cout<<"nVar="<<nVar<<"nVarfile="<<nVarFile<<endl; iLine = 0; while (getline (bc_file, text_line)) { stringstream linestream(text_line); linestream >> bc_dat_point[iLine]; //Global index of boundary point cout<<"bc_dat_point="<<bc_dat_point[iLine]<<endl; for (iVar = 0; iVar < nVar; iVar++) {linestream >> bc_dat[iLine][iVar]; cout<<"bc_dat="<<bc_dat[iLine][iVar]<<endl; } iLine++; } /*--- Loop over all of the vertices on this boundary marker ---*/ SU2_OMP_FOR_STAT(OMP_MIN_SIZE) for (iVertex = 0; iVertex < geometry->nVertex[val_marker]; iVertex++) { /*--- Get the point index for the current node. ---*/ iPoint = geometry->vertex[val_marker][iVertex]->GetNode(); /*--- Check if the node belongs to the domain (i.e, not a halo node) ---*/ su2double Solution[MAXNVAR] = {0.0}; su2double SOL[MAXNVAR] = {0.0}; if (geometry->nodes->GetDomain(iPoint)) { fndBnd = false; //Haven't found this boundary point as yet for (iBnd = 0; iBnd < geometry->nVertex[val_marker]; iBnd++) { if (bc_dat_point[iBnd] == geometry->nodes->GetGlobalIndex(iPoint)) { for (iVar = 0; iVar < nVar; iVar++) {Solution[iVar] = bc_dat[iBnd][iVar]; cout<<"solution"<<Solution[iVar]<<endl; } fndBnd = true; break; } } if (!fndBnd) { if (rank == MASTER_NODE) cout << "Failed to find solution for point index " << geometry->nodes->GetGlobalIndex(iPoint) << " in " << bc_filename << endl; exit(EXIT_FAILURE); } /*--- Set Solution and zero Residual ---*/ for (iVar =0;iVar<nVar;iVar++){ nodes->SetSolution_Old(iPoint,iVar, Solution[iVar]); nodes->SetSolution(iPoint,iVar, Solution[iVar]); } LinSysRes.SetBlock_Zero(iPoint); nodes->SetRes_TruncErrorZero(iPoint); for (iVar =0;iVar<nVar;iVar++){ SOL[iVar]=GetNodes()->GetSolution(iPoint,iVar); cout<<"Solution updated"<<SOL[iVar]<<endl; } } END_SU2_OMP_FOR } } } I am unable to find what mistake i am doing, plz help. |
bc_custom, su2 7.1.1 |
sliding mesh problem in CFX | Saima | CFX | 46 | September 11, 2021 08:38 |
Centrifugal fan | j0hnny | CFX | 13 | October 1, 2019 14:55 |
Radiation in semi-transparent media with surface-to-surface model? | mpeppels | CFX | 11 | August 22, 2019 08:30 |
Error - Solar absorber - Solar Thermal Radiation | MichaelK | CFX | 12 | September 1, 2016 06:15 |
Question about heat transfer coefficient setting for CFX | Anna Tian | CFX | 1 | June 16, 2013 07:28 |
