Home > Forums > Software User Forums > SU2
iPoint, iMarker, and iVertex; and problem with MPI
Old   August 4, 2021, 01:51
Default iPoint, iMarker, and iVertex; and problem with MPI
Zhen ZHANG
Zhen ZHANG is on a distinguished road
Hi all,
I got a problem when setting values at the boundary to the volume data container.
I created a VectorType member sens_inlet in the CEulerSolver class and resized it to nPoint.
I then registered the Tt of all vertices at the inlet boundary. After extracting the sensitivity, I set them to the sens_inlet using the following codes:
for(unsigned short iMarker=0; iMarker < config->GetnMarker_All(); iMarker++) {
  for (unsigned long iVertex = 0; iVertex < geometry->GetnVertex(iMarker); iVertex++) {
    unsigned long iPoint = geometry->nodes->GetGlobalIndex(geometry->vertex[iMarker][iVertex]->GetNode());
    nodes->SetSens_Inlet_T(iPoint,SU2_TYPE::GetDerivative(Inlet_Ttotal[iMarker][iVertex]))}}
The orders of registration and extraction are the same.
However, in the result file, the non-zero values of the sens_inlet do not appear at the inlet boundary (see the attached figure). If running with MPI, it returns an error "Assertion `i>=0 && i<m_rows' failed".
Could anybody give me some clues why this problem happen? Thanks in advance!
Zhen ZHANG is offline   Reply With Quote
Old   August 4, 2021, 03:10
Zhen ZHANG
Well, I changed the iPoint calculation to
unsigned long iPoint = geometry->vertex[iMarker][iVertex]->GetNode();
and it works.
What is the difference between these two calculations?
Thanks,
Zhen
