Home > Forums > Software User Forums > SU2
[gmsh exporting su2 mesh] how to add physical name tags to boundary surfaces?
Old   July 29, 2021, 23:20
Default [gmsh exporting su2 mesh] how to add physical name tags to boundary surfaces?
Shenren Xu
Shenren_CN is on a distinguished road
Hello all,
I have prepared a valid Gmsh mesh file (.msh) and exported the mesh to su2 format from Gmsh. I have inspected the exported su2 mesh file using Pointwise and found that the boundaries surfaces come with name tags such as 'PhysicalSurface1'. This always gave me sufficient information for me to construct a .cfg file in order to run SU2_CFD. However, it is a bit inconvenient as these names don't carry any meaning, are non-intuitive, and it's error-prone. Therefore, I would like to rename the boundaries surfaces using names such as 'INLET', 'PER1_UP', 'PER1_LOW', 'OUTLET', etc.
How do I do this? I was not able to find a way to add this information in Gmsh. In addition, I would like to have a workflow without Pointwise. Could anyone please suggest me a way to go about this?
Thanks.
Shenren
Shenren_CN is offline   Reply With Quote
Old   July 30, 2021, 09:16
bigfoot
bigfootedrockmidget is on a distinguished road
in gmsh, the boundary conditions are called physical groups. In 2D, you select the boundary lines and give them a descriptive name, like inlet or outlet, in 3D, you select surfaces. You usually also select the entire body (the plane in 2D or the volume in 3D) and give it a name like 'fluid_body'. When you export the mesh to su2, you only need to export the physical entities/groups. Any additional points or lines that you have created but do not want in your final mesh will then not be written to the su2 file.
bigfootedrockmidget is offline   Reply With Quote
Gmsh does not ouput SU2 markers from physical surfaces stewels SU2 4 May 17, 2023 06:15
Table bounds warnings at: END OF TIME STEP CFXer CFX 4 July 17, 2020 00:44
My radial inflow turbine Abo Anas CFX 27 May 11, 2018 02:44
[Gmsh] How to add a prismatic-cell boundary layer in GMSH? klausb OpenFOAM Meshing & Mesh Conversion 4 November 22, 2016 18:30
[PyFoam] and paraview eelcovv OpenFOAM Community Contributions 28 May 30, 2016 10:23
