Home > Forums > Software User Forums > SU2
Fine grid for Double wedge test case
Old   July 27, 2021, 06:03
Default Fine grid for Double wedge test case
Dr. H.K. Narahari
hk.narahari is on a distinguished road
I have successfully run NEMO test cases in the repository (inviscid wedge and viscwedge). One of the cases mentioned in the literature is a Double wedge, I was wondering if someone has tried out the case at Hypersonic Mach number. I remember seeing the results in a presentation on NEMO with Mutations ++ by Dr. C. Garbacz et al. I would like to get a pointer to that GRID if it is available in open domain of course.
Regards and Thanks in advance
Narahari
hk.narahari is offline   Reply With Quote
hypersonic, nemo
On grid independent solution for pulsatile flow David FLUENT 5 March 25, 2022 04:33
VOF Grid Independence Test pokhrel Fluent Multiphase 0 February 20, 2017 16:45
Problem with grid sensitive test cases(shock instability) in SU2.!!! Vino SU2 2 November 27, 2014 05:33
Interfoam Droplet under shear test case adona058 OpenFOAM Running, Solving & CFD 3 May 3, 2010 19:46
coarse grid to fine grid crashing Arnab Siemens 1 February 22, 2005 13:27
