Home > Forums > Software User Forums > SU2
Turbulent channel with a bump - SU2 Cp problem
Old   July 19, 2021, 05:08
Default Turbulent channel with a bump - SU2 Cp problem
Pedro Paulo
pedropcb13 is on a distinguished road
Hi everyone,
I am simulating the turbulent channel with a bump using SU2. The same one in this repository: https://github.com/su2code/VandV/blo...rb_bump_sa.cfg
I am using the grids from the NASA website: https://turbmodels.larc.nasa.gov/bump_grids.html
The original .cgf file in the mentioned repository is for Mach 0.20. When changing the Mach to 0.21, I update the BC using the isentropic flow equations. (Pt/Po = 1.031211844 & Ttot/To = 1.00882, for Mach = 0.21)
So that the updated BC for Mach 0.21 in the .cfg file are:
% Velocity inlet marker
MARKER_INLET= ( inlet, 302.646, 70816.204742, 1.0, 0.0, 0.0 )
% Pressure outlet marker
MARKER_OUTLET= ( outlet, 68672.8 )
The simulation converges, however, the Cp values does not make sense when I do that. What else should I change in the .cfg file to simulate Mach 0.21?
pedropcb13 is offline   Reply With Quote
Old   July 19, 2021, 06:28
Pedro Paulo
Problem solved!
Unfortunately there is no way to delete the post.
Old   July 23, 2021, 05:41
na
TKatt is on a distinguished road
Hi, glad you solved your problem
If you don't mind, maybe you can post your solution here briefly, it might help others to understand their problems
best, Tobi
TKatt is offline   Reply With Quote
cp values, su2, turbulent channel w bump
Turbulent transition in channel flow yansheng STAR-CCM+ 11 June 16, 2016 10:05
Calculate statistics of Turbulent channel flow with LES sjwon1991 Main CFD Forum 2 May 11, 2016 00:31
LES of Turbulent Channel Flow; increased flux for some models? Selvinus Main CFD Forum 14 September 29, 2015 06:15
Turbulent Separation problem fluidmechanics FLUENT 1 September 7, 2015 14:59
LES: Turbulent Channel Flow without initial solution (BC) DaSh OpenFOAM Running, Solving & CFD 21 February 8, 2015 17:09
