Home > Forums > Software User Forums > SU2
NEMO - SU2 NONEQ with 3D-grid (Euler or Navier Stokes) doesn't start
Old   June 28, 2021, 09:04
Default NEMO - SU2 NONEQ with 3D-grid (Euler or Navier Stokes) doesn't start
Maximilian Brandt
MBrandt is on a distinguished road
Hello my friends I´m new here and my research area are hypersonic waverider geometries. I´m intersting to do some simulations with NEMO-Navier_Stokes und der Air-5 library, but when I start my simulation it ends at the point "NO Jacobian structure" and the calculation doesn't start ... (please refer picture)
Is the NEMO-Solver actually not yet suitable for 3D grids (in my appendix is the config-File)?
Thank you for your answers.
Best
Maximilian
MBrandt is offline   Reply With Quote
Old   June 28, 2021, 15:09
Wally Maier
wallym is on a distinguished road
Hi Maximilian,
Thanks for using NEMO! and thanks for your question. NEMO works for 3D simulations.
The no jacobian structure is all good, this simply means you are running an explicit simulation. I am in the process of verifying the implicit capabilities.
Unfortunately, one of the biggest issues with NEMO is speed. Running large grids will take a while to get through the preprocessing stage and is best done in parallel. The link with Mutation++ runs much quicker (though is still slower than a typical simulation).
Id be happy to help out with other problems you may run into and try to help.
Best,
Wally
wallym is offline   Reply With Quote
On grid independent solution for pulsatile flow David FLUENT 5 March 25, 2022 04:33
wrong SU2 calculation for lift and drag coefficient for NAC4421 mechy SU2 7 January 9, 2017 06:18
Which grid generator for SU2? Chris Lee SU2 3 October 3, 2014 13:59
best setting for SU2 mechy SU2 3 April 20, 2014 20:13
Possible Bug in pimpleFoam (or createPatch) (or fluent3DMeshToFoam) cfdonline2mohsen OpenFOAM 3 October 21, 2013 10:28
