Shift in PSD peaks with increased inner iterations |
June 15, 2021, 11:12 |
Ravi
Rep Power: 9 |
Hello all,
I am currently running a DDES, 2nd order unsteady simulation for an airfoil in deep stall (angle of attack = 60). The time discretization was performed by using a dual time-stepping scheme. I was trying to converge the results obtained from SU2, and compare the variation of experimental data by increasing the number of inner iterations. I seem to be finding it difficult to obtain a physical reason behind the shift in the peak frequency for which I have obtained. In consultation with another colleague, I got to know that the reason could be because of the absence of ensemble averaging. I would be grateful to hear from someone regarding their opinion on this matter. The experimental data and the computational results were obtained from Swalwell et. al. and the DESider project respectively, whose sources are presented below: Hoping to hear soon. References: Katrina E Swalwell, John Sheridan, WH Melbourne, et al. The effect of turbulence intensity on stall of the naca 0021 aerofoil. In 14th Australasian fluid mechanics conference, pages 10–14, 2001. Werner Haase, Marianna Braza, and Alistair Revell.DESider–A European Effort on HybridRANS-LES Modelling: Results of the European-Union Funded Project, 2004-2007, volume103. Springer Science & Business Media, 2009. |
laplacianFoam with source term | Herwig | OpenFOAM Running, Solving & CFD | 17 | November 19, 2019 14:47 |
Segmentation fault when using reactingFOAM for Fluids | Tommy Floessner | OpenFOAM Running, Solving & CFD | 4 | April 22, 2018 13:30 |
chtMultiRegionSimpleFoam turbulent case | Aditya Patil | OpenFOAM Running, Solving & CFD | 6 | April 24, 2017 23:13 |
Moving mesh | Niklas Wikstrom (Wikstrom) | OpenFOAM Running, Solving & CFD | 122 | June 15, 2014 07:20 |
calculation stops after few time steps | sivakumar | OpenFOAM Running, Solving & CFD | 7 | March 17, 2013 07:37 |
