Home > Forums > Software User Forums > SU2
Custom objective function
Old   June 1, 2021, 16:10
Default Custom objective function
Umut Can
Umuteng is on a distinguished road
Hi all,
I think i need a starting point for defining user-defined objective function?
So where should i start?
Thanks
Umuteng is offline   Reply With Quote
Old   June 2, 2021, 04:14
bigfoot
bigfootedrockmidget is on a distinguished road
There is an objective function in place that you can modify for your own use.
look for
custom_objfunc
in the code. You can also look at a standard objective function like
surface_uniformity
to see how it is done.
In vscode, you can search case-insensitive to find all all occurences.
bigfootedrockmidget is offline   Reply With Quote
Old   June 2, 2021, 15:11
Umut Can
thanks a lot!
[Other] refineWallLayer Error Yuby OpenFOAM Meshing & Mesh Conversion 2 November 11, 2021 12:04
whats the cause of error? immortality OpenFOAM Running, Solving & CFD 13 March 24, 2021 08:15
Running UDF with Supercomputer roi247 FLUENT 4 October 15, 2015 14:41
is internalField(U) equivalent to zeroGradient? immortality OpenFOAM Running, Solving & CFD 7 March 29, 2013 02:27
Mass Flow Rate Custom Field Function AJoubert FLUENT 2 March 23, 2013 09:50
