Home > Forums > Software User Forums > SU2
Relationship between flow and turbulence solvers
Old   May 22, 2021, 08:49
Post Relationship between flow and turbulence solvers
Zhen ZHANG
Zhen ZHANG is on a distinguished road
Hi all,
When simulating a turbulent flow, the flow solver and the turbulence solver should be built. My questions are how these two solvers are arranged in the solver pointer, and how they transfer data.
Can anyone give me some clues? Or which part of the codes can be referred to?
Thanks in advance!
zhen
Zhen ZHANG is offline   Reply With Quote
Old   May 22, 2021, 09:12
bigfoot
bigfootedrockmidget is on a distinguished road
Maybe you can start in the file cSolverFactory.cpp. There you see that a solver class is created for each of the solvers: a flow solver (e.g. incompressible Euler), a turbulence solver (e.g. SA model), etc. they are collected in solver_container.
The solvers are independent, but information is transferred. For the flow solver, we need the turbulent viscosity. The solver_container is basically an array containing your solvers. So inside the flow solver, you can access information from the turbulence solver through the solver_container, for instance by saying:
solver_container[TURB_SOL]->GetNodes()->GetmuT(iPoint);
And in the turbulence model, we access the solution of the flow solver in a similar way.
Is this pointing you in the right direction?
bigfootedrockmidget is offline   Reply With Quote
Old   May 22, 2021, 11:25
Smile
Zhen ZHANG
Yes, I understand, Thank you!
Old   May 23, 2021, 08:54
Zhen ZHANG
I have another related question, what are the indexes of the solver container such as solver[iZone][iInst][MESH_0][FLOW_SOL]?
Zone is for multiphysics, Mesh is for multigrid, and SOL is for different solver types. Is it right? And what is the instance?
Thanks!
Old   May 23, 2021, 11:30
pcg
Pedro Gomes
pcg is on a distinguished road
Time instance for harmonic balance.
pcg is offline   Reply With Quote
Old   May 23, 2021, 21:58
Zhen ZHANG
Got it. Thank you!
Low Re Turbulence model VS Low Re flow and Turbulence Modelling background pchoopanya Main CFD Forum 4 May 10, 2018 12:05
About Turbulence Intensity (Pipe flow assimilated) gRomK13 Main CFD Forum 1 July 10, 2009 04:11
Discussion: Reason of Turbulence!! Wen Long Main CFD Forum 3 May 15, 2009 10:52
Code release: Flow Transition and Turbulence Chaoqun Liu Main CFD Forum 0 September 26, 2008 18:15
Natural convection - Inlet boundary condition max91 CFX 1 July 29, 2008 21:28
