May 14, 2021, 08:42 |
Mesh not read after restart
Mauro Minervino
Rep Power: 8 |
I'm running a propeller blade simulation using steady RANS in rotating reference frame and SU2_CFD v707. After convergence, I deformed (externally) the mesh to modify the blade pitch angle and restarted from last converged solution, but apparently the solver does not 'see' the modified mesh but keeps on using gird coordinates as included in the restart file. It worked on version 5 "RAVEN". Any suggestion? Thanks. Mauro |
May 14, 2021, 09:34 |
Pedro Gomes
Rep Power: 13 |
Can you provide a minimal example of the problem? it helps if we can "see" immediately what is wrong without having to guess what configuration options you used. I can kinda imagine why that would happen though... I'm working on fixing similar issues. Cheers, Pedro |
May 14, 2021, 09:44 |
#3 | |
Mauro Minervino
Rep Power: 8 |
Regards, M |
sliding mesh problem in CFX | Saima | CFX | 46 | September 11, 2021 07:38 |
[Commercial meshers] Problems with ANSYS mesh conversion | tdog | OpenFOAM Meshing & Mesh Conversion | 1 | March 31, 2016 17:36 |
[mesh manipulation] Importing Multiple Meshes | thomasnwalshiii | OpenFOAM Meshing & Mesh Conversion | 18 | December 19, 2015 18:57 |
Restart Deforming Mesh Calculation | Tristan | CFX | 0 | June 22, 2009 18:34 |
Icemcfd 11: Loss of mesh from surface mesh option? | Joe | CFX | 2 | March 26, 2007 18:10 |
