Rep Power: 5 ![]() |
Looking at the values of the "Eddy_Viscosity" variable in a (tecplot ascii format) field output of a RANS SA calculation (SU2 v7.0.6), I wondered if this variable should be interpreted as a dynamic or kinematic viscosity . Does anybody know? Thanks in advance, Gérald |
bigfoot
Rep Power: 17 ![]() |
SA solves a transport equation for the kinematic turbulent eddy viscosity. The effective viscosity is then the sum of the regular kinematic viscosity and the turbulent viscosity. When the flow is turbulent, the turbulent eddy viscosity almost always dominates and the 'laminar' kinematic viscosity is often negligible. See also:
https://en.wikipedia.org/wiki/Spalar...rbulence_model |
eddy_viscosity |
Clarification for the RANS-based turbulence model | cfdnewb123 | Main CFD Forum | 6 | April 27, 2020 13:10 |
Concluding from Eddy Viscosity Ratio to Total Height of Prisms | pamstad | CFX | 3 | December 5, 2019 16:30 |
Eddy Viscosity Suppressed in Front of Cylinder | ngj | OpenFOAM Running, Solving & CFD | 6 | September 1, 2013 06:14 |
OpenFOAM static build on Cray XT5 | asaijo | OpenFOAM Installation | 9 | April 6, 2011 12:21 |
Question about eddy viscosity ratio limit | Piti | CFX | 2 | January 17, 2008 16:49 |
