Problem with cfg file for SU2 simulation over airfoil |
Cb
Rep Power: 0 ![]() |
I'm having a hard time with the configuration file. I'm trying to simulate flow over an airfoil using the RANS equations and the Spalart Allmaras Model. I'm running into a two dimensional problem. The error I run into reads Two dimensional problem. 344 points. 2 surface markers. 250 boundary elements in index 0 (Marker = farfield). 98 boundary elements in index 1 (Marker = airfoil). I attached my cfg file .geo file and su2 file that I am using. Any help would be greatly appreaciated I'm so lost as to what I configured incorrectly. |
bigfoot
Rep Power: 17 ![]() |
Hi!
Which version are you using? Many of the options in your configuration file are obsolete so I could not test this with a recent version. Can you get the most recent release and try it again?The configuration files in the testcases directory are up to date so you can start with one of those. |
Custom Thermophysical Properties | wsmith02 | OpenFOAM | 4 | June 1, 2023 14:30 |
[OpenFOAM.org] Compile OF 2.3 on Mac OS X .... the patch | gschaider | OpenFOAM Installation | 225 | August 25, 2015 19:43 |
[Other] Adding solvers from DensityBasedTurbo to foam-extend 3.0 | Seroga | OpenFOAM Community Contributions | 9 | June 12, 2015 17:18 |
SparceImage v1.7.x Issue on MAC OS X | rcarmi | OpenFOAM Installation | 4 | August 14, 2014 06:42 |
"parabolicVelocity" in OpenFoam 2.1.0 ? | sawyer86 | OpenFOAM Running, Solving & CFD | 21 | February 7, 2012 11:44 |
