Home > Forums > Software User Forums > SU2
Parabolic Velocity inlet profile error
Old   April 16, 2021, 11:48
Default Parabolic Velocity inlet profile error
Daniel Fairchild
guerillagecko is on a distinguished road
I am trying to set up an FSI problem which uses a custom Parabolic inlet profile. I have followed the steps outlined in the Incompressible Laminar step tutorial and created an inlet profile file, however, when I run it with the specified inlet profile I get the error "requesting a negative iteration number for the restart file!!".
It runs absolutely fine with a uniform inlet profile though, I'm relatively new to SU2 so I'm having trouble trying to figure out what the error actually means.
Any insight on this problem would be much appreciated,
Dan
guerillagecko is offline   Reply With Quote
Old   April 16, 2021, 18:09
pcg
Pedro Gomes
pcg is on a distinguished road
For multizone, files need a zone suffix (inletprofile_0.dat), for timedomain they need a further time suffix inletprofile_0_0000.dat
Possibly you are not restarting and there is a bug in the code, I will have a look, in the meantime you can try running 2 iterations without the inlet profile, and then restarting with the profile.
Edit: It was a bug -> https://github.com/su2code/SU2/pull/1264
You can either use that branch or the dummy restart trick above.
pcg is offline   Reply With Quote
inlet profile, parabolic inlet
[OpenFOAM.org] compile error in dynamicMesh and thermophysicalModels libraries NickG OpenFOAM Installation 3 December 30, 2019 01:21
long error when using make-install SU2_AD. tomp1993 SU2 Installation 3 March 17, 2018 07:25
Problem with compile the setParabolicInlet ivanyao OpenFOAM Running, Solving & CFD 6 September 5, 2008 21:50
Compiling problems with hello worldC fw407 OpenFOAM Installation 21 January 6, 2008 18:38
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 18:51
