Home > Forums > Software User Forums > SU2
How to compute Reynolds number from information in inv_NACA0012.cfg ?
Old   April 7, 2021, 13:55
Default How to compute Reynolds number from information in inv_NACA0012.cfg ?
Harry Kim
hkim716 is on a distinguished road
I'm struggling about calculating Reynolds number based on the flow conditions given in "inv_NACA0012.cfg" file. (txt file attached)
According to the free-stream definition in the .cfg file,
Mach number = 0.8 and Freestream Temperature = 273.15
I could calculate Reynolds number using
Re = (Freestream vel* Length of Airfoil)/Kinematic viscosity
= (Mach number*Speed of Sound @ 273K * Length of Airfoil)/Kinematic vis
How to know "Length of the Airfoil" to calculate Free-stream Reynolds Number based on information in the .cfg file?
If I have something wrong for Re calculation, please correct me.
FYI, this is the simplest test case for SU2 in the QuickStart tutorial.
Thanks in advance!
hkim716 is offline   Reply With Quote
Old   April 9, 2021, 00:35
Amit
aero_amit is on a distinguished road
You need not input the Reynolds number for inviscid flow calculations. Adequate information is supplied in the file you have attached (M, P, T).
Also reference length is mentioned here in file for this case as -
REF_LENGTH= 1.0.
Anyways, you can work out Reynolds number as -
Re=Rho*V*Lref/mu
Get Rho from P, T. Obtain V=Mach*sqrt(Gamma*R*T), Lref is specified and mu can be computed from Sutherland's formula.
aero_amit is offline   Reply With Quote
Old   April 9, 2021, 00:53
Harry Kim
REF_LENGTH= 1.0.
Re=Rho*V*Lref/mu
Oh, you are right. Reynolds number in inviscid flow is theoretically infinite. I was just stupid being confused with viscous flow. Thanks for reminding me that!
naca0012
Decomposing meshes Tobi OpenFOAM Pre-Processing 22 February 24, 2023 09:23
GenerateVolumeMesh Error - Surface Wrapper Self Interacting (?) AndreP STAR-CCM+ 10 August 2, 2018 07:48
[OpenFOAM.org] OF2.3.1 + OS13.2 - Trying to use the dummy Pstream library aylalisa OpenFOAM Installation 23 June 15, 2015 14:49
SigFpe when running ANY application in parallel Pj. OpenFOAM Running, Solving & CFD 3 April 23, 2015 14:53
Question about momentum thickness Reynolds number Anna Tian Main CFD Forum 2 March 4, 2013 10:45
