April 7, 2021, 10:55 |
Manual initialization in SU2
Zhen ZHANG
Rep Power: 8 |
Hi all,
I am dealing with film cooling problems, where there are many inlets. The default uniform initialization does not work. Can I manually initialize the calculation domain? For example, different velocities and pressure in different regions. To do so, which part of the source code should I modify? Thanks! |
April 10, 2021, 08:24 |
bigfoot
Rep Power: 21 |
The easiest is maybe this: save the results after 1 iteration as an ASCII file using Code:
READ_BINARY_RESTART= NO OUTPUT_FILES= RESTART_ASCII You can manipulate this file using your favorite tool (matlab, python work very well) Then restart from this file. |
April 12, 2021, 04:22 |
Solved!
#3 | |
Zhen ZHANG
Rep Power: 8 |
initialization method |
Introducing SU2 International Developers Society (IDS) | fpalacios | SU2 News & Announcements | 1 | June 17, 2019 23:38 |
Looking for manual, instructions, tutorials and so on how to use SU2 | mostanad | SU2 | 1 | April 27, 2016 11:53 |
SU2 shape optimization initialization method? | gina07 | SU2 Shape Design | 1 | May 2, 2015 17:40 |
SU2 User Manual? | jzhen | SU2 | 2 | February 17, 2015 16:53 |
Welcome to the Stanford University Unstructured (SU2) forum! | economon | SU2 | 0 | January 7, 2013 03:48 |
