Home > Forums > Software User Forums > SU2
Aerodynamic heating in SU2
Old   March 11, 2021, 04:14
Default Aerodynamic heating in SU2
Rebeca is on a distinguished road
Hello.
I'm trying to calculate the aerodynamic heating of a plane that is flying in a defined trayectory. Is it possible to use SU2 or with SU2 I will only obtain the temperature field of the fluid, not over the surface?
Thank you in advance.
Rebeca is offline   Reply With Quote
Old   March 12, 2021, 06:25
Ole Burghardt
Sprotte is on a distinguished road
what do you mean by "not over the surface" ?
Heat fluxes can e.g. be computed by setting a temperature boundary condition and letting SU2 evaluate them at that boundary just like it does for Cd, Cl, etc.
Best, Ole
Sprotte is offline   Reply With Quote
Old   March 12, 2021, 06:56
Post
Thank you for answering! I want to calculate the temperature's evolution over the surface of a body inmersed in a particular flow (aerodynamic heating) and I don't know if SU2 is capable of calculating that taking into account the body's material, etc. I mean, I'm not interested on what happens with the flow, just the body (for example, to make sure the body is not going to melt because of the aerodynamic heating in a particular condition).
Best,
Rebeca
Old   March 12, 2021, 07:19
Ole Burghardt
Are you talking about multiphysics, air flow plus heat distribution in a body, similar to the problem in this tutorial https://su2code.github.io/tutorials/...ted_Cylinders/ ?
Old   March 12, 2021, 07:40
Yes! That is what I'm talking about. Thank you so much!
Old   March 12, 2021, 16:01
Ole Burghardt
Sure. Let's see how it works for your case. Leave me a note in case you encounter any problems
Aerodynamic heating in Fluent Oleg V. FLUENT 6 July 22, 2019 13:41
Aerodynamic heating distribution around a blunt body mecha1705 STAR-CCM+ 2 July 14, 2019 17:26
Introducing SU2 International Developers Society (IDS) fpalacios SU2 News & Announcements 1 June 17, 2019 23:38
Fluent: Species Mass Fraction - Aerodynamic Heating at Hypersonic Flight Advanced FLUENT 0 July 21, 2018 05:38
Aerodynamic Heating J. Julia Main CFD Forum 1 August 9, 1998 13:10
