How to set a exit boundary where the static pressure changing with time? |
February 6, 2021, 02:44 |
Rep Power: 7 |
Hi, hope everything goes well. Just one quick question, does SU2 has a boundary condition with static pressure changing with time? I want to run an unsteady simulation, I need to set a static pressure at the outlet of a duct and make it gradually increase with time.
I know there is a RAMP_OUTLET_PRESSURE_COEFF in the turbomachinery simulation, but this is for steady case, right? I tested a very simple case in the unsteady simulation and I can see the static pressure seems to change with time as well. Just to double check, does it work in unsteady case? |
February 6, 2021, 04:17 |
#2 | |
Table bounds warnings at: END OF TIME STEP | CFXer | CFX | 4 | July 17, 2020 00:44 |
Time dependant pressure boundary condition | yosuke1984 | OpenFOAM Verification & Validation | 3 | May 6, 2015 07:16 |
dynamic Mesh is faster than MRF???? | sharonyue | OpenFOAM Running, Solving & CFD | 14 | August 26, 2013 08:47 |
Low Mixing time Problem | Mavier | CFX | 5 | April 29, 2013 01:00 |
RPM in Wind Turbine | Pankaj | CFX | 9 | November 23, 2009 05:05 |
