Home > Forums > Software User Forums > SU2
Unusually large initial Cd upon starting my simulation, is this normal?
Old   February 5, 2021, 12:49
Default Unusually large initial Cd upon starting my simulation, is this normal?
Bradley Craig
Creg is on a distinguished road
Hi everyone,
Upon starting my simulation the Cd listed is unbelievably high, as you can see it does begin to fall but it seems as though it would take an age to be what would be expected for the cylindrical case im running.
I have run a previous simulation of a similar case where the geometry was simply 1/5 of the current size and this resulted in results that made sense.
Does this fact mean there is an issue with my simulation or is this to be expected?
I have attatched my, mesh and a screenshot of the solver for convenience.
Many thanks in advance
Creg is offline   Reply With Quote
Old   February 6, 2021, 04:13
Pay D.
pdp.aero is on a distinguished road
Originally Posted by Creg View Post
Hi everyone,
I don't know what is your physical problem but as long as you converge to the right answer initial calculations just can be considered as initial guess.
But if you don't, you must double check everything, including your initial condition.
Initial condition includes your flow condition and boundary condition.
Then check your reference values, for your 2D case it is the reference length. For example for an airfoil reference length is the chord length that usually is scaled to 1.
If flow and boundary condition and reference values are all right, you should converge to the right answer!
pdp.aero is offline   Reply With Quote
Old   February 6, 2021, 06:28
Bradley Craig
Thanks for replying I appreciate it.
Is it common for the cd to start so high though? I'd expect it to be around 1 but it starts at 500M and furthermore, takes an age to converge. Whereas with the smaller scale case and coarser mesh the initial cd is already almost as Id expect and thus converges in a fraction of the time. (3hours vs 22hours)
Is this just an inherent property of cfd that upon refining the mesh the initial guess gets huge?
Old   February 6, 2021, 08:33
Amit
aero_amit is on a distinguished road
If you can share the cfg file/case, it may help in answering better ....
aero_amit is offline   Reply With Quote
Old   February 6, 2021, 09:01
Bradley Craig
Of course, apologies. Here are both my mesh and cfg file
Old   February 6, 2021, 11:41
Bradley Craig
Fixed!! Thanks for your time, I had just misstyped my Reynolds number
drag coefficient
[solidMechanics] Support thread for "Solid Mechanics Solvers added to OpenFOAM Extend" bigphil OpenFOAM CC Toolkits for Fluid-Structure Interaction 686 December 22, 2022 10:10
HeatSource BC to the whole region in chtMultiRegionHeater xsa OpenFOAM Running, Solving & CFD 3 November 7, 2016 06:07
Floating point exception error lpz_michele OpenFOAM Running, Solving & CFD 53 October 19, 2015 03:50
Compressor Simulation using rhoPimpleDyMFoam Jetfire OpenFOAM Running, Solving & CFD 107 December 9, 2014 14:38
SLTS+rhoPisoFoam: what is rDeltaT??? nileshjrane OpenFOAM Running, Solving & CFD 4 February 25, 2013 05:13
