Home > Forums > Software User Forums > SU2
SU2 process returned error '15' during optimization
Old   January 23, 2021, 10:18
Default SU2 process returned error '15' during optimization
Bikalpa Bomjan Gurung
bikalpa10 is on a distinguished road
Hello everyone,
I am using the SU2_7.0.6 version for 3d optimization with High-Performance Computer having 40 processors on each node. My slurm file is as follows.
#!/bin/bash
#SBATCH --job-name=Delta_5
#SBATCH --nodes=3
#SBATCH --ntasks=120
#SBATCH --time=24:00:00
#SBATCH -o slurmjob-%j.out
#SBATCH -e slurmjob-%j.err
module load compiler/openmpi/3.1.0/gnu
module load python/3.6
export SU2_RUN=/home/apps/su2_7.0.6_AD_support/SU2_7.0.6/bin
export SU2_HOME=/home/apps/su2_7.0.6_AD_support/SU2_7.0.6/SU2-7.0.6
export PATH=$PATH:$SU2_RUN
export PYTHONPATH=$PYTHONPATH:$SU2_RUN
export SU2_MPI_COMMAND="mpirun -np %i %s"
shape_optimization.py -n 120 -o SLSQP -f turb_Corr_Del_5_optimisation.cfg
While using more than 1 node for optimization it runs for 2-3 iterations and the optimization stops with the error message
“SU2 process returned error '15'
Abort(811688463) on node 17 (rank 17 in comm 0): Fatal error in PMPI_Finalize: Other MPI error, error stack:
PMPI_Finalize(367)...............: MPI_Finalize failed
PMPI_Finalize(278)...............:
MPID_Finalize(1033)..............:
MPIDI_OFI_mpi_finalize_hook(1579): OFI domain close failed (ofi_init.c:1579:MPIDI_OFI_mpi_finalize_hookevic e or resource busy) ”
The process runs for 2-3 more iteration when restarting the project and the same error repeats.
Please suggest what might be causing this error and how I can overcome this issue.
Thank you
Regards
bikalpa10 is offline   Reply With Quote
Old   August 11, 2024, 07:20
Ercan Umut
CleverBoy is on a distinguished road
Hello Bikalpa,
Were you able to solve this problem?
CleverBoy is offline   Reply With Quote
SU2 Optimization multiple FFD boxes error StanislavKarpuk SU2 Shape Design 0 November 20, 2019 16:51
Introducing SU2 International Developers Society (IDS) fpalacios SU2 News & Announcements 1 June 17, 2019 23:38
Pointwise-SU2 joint webinar (April 29th) and SU2 v3.1.0 new release fpalacios SU2 News & Announcements 1 April 30, 2014 03:40
error 262144 and unexpected disconnect when run on 2 nodes Emily1412 SU2 Installation 1 April 10, 2014 18:08
How to setup a simple OpenFOAM cluster? TommiPLaiho OpenFOAM Installation 3 October 27, 2013 16:15
