Wind turbine blade gradient-based constrained optimisation |
Rep Power: 0 ![]() |
After checking the internet to see if others have used SU2 for constrained gradient-based optimization in wind turbine applications, I did not find much information. The tutorials on SU2's website for constrained optimization are for flow regimes not applicable to wind turbines. I came across this article Implementation of a pressure based incompressible flow solver in SU2 for wind turbine applications which is one of the few showing the application of SU2 in wind turbine modelling. However, there are not many references. Can someone please provide some information about the status of SU2 applied to wind turbine blade optimization (incompressible regime, low Mach number, fixed and rotating reference frame, constrained gradient-based optimization, continuous and discrete adjoints). Thank you! |
Akshay Koodly
Rep Power: 9 ![]() |
I am still working on the pressure based solver (which is still a separate branch) and have had some limited success with wind turbine simulations with the pressure based solver. You can try it by downloading the code from https://github.com/su2code/SU2/tree/...Pressure_based and building from source. The results in that paper are from the compressible solver. It is not possible to use the pressure based with the adjoint solver. There was a recent development that updated the rotating reference frame for the density based incompressible solver in the main branch which you can also try. I am not aware of any adjoints or optimization simulations for wind turbines however. Cheers |
Thanks for your response akoodlyr. I'll have a look and see from there.
simpleFoam - MRF - Wind Turbine Blade | Aeronautics El. K. | OpenFOAM Running, Solving & CFD | 7 | June 2, 2021 19:06 |
[BladeModeler] Geometry and Meshing for Failure Analysis of Wind turbine blade | Wajeeh | ANSYS Meshing & Geometry | 0 | December 30, 2020 05:17 |
Designing a New wing blade for a wind turbine | Sideption | Main CFD Forum | 1 | May 8, 2018 04:02 |
Can I use Turbogrid to mesh a wind turbine blade? | Henry Liu | CFX | 10 | November 10, 2011 05:41 |
Wind tunnel of a turbine blade tests. | Jonas Pedro Caumo | CFX | 3 | April 28, 2007 02:35 |
