Home > Forums > Software User Forums > SU2
Case Over Ma5 Always Fail
Old   December 21, 2020, 08:29
Default Case Over Ma5 Always Fail
ShiheJia is on a distinguished road
hello everyone;
Recently I have been testing the limitation of the range of mach number and complex cases. And I found something wrong with the newest version.
When I use 0012 airfoil to test the limitation of mach number , I found over ma5 the solver will exit with error just as following:
Error in "void CSysSolve<ScalarType>::ModGramSchmidt(int, std::vector<std::vector<ScalarType> >&, std::vector<CSysVector<ScalarType> >&) const [with ScalarType = double]":
FGMRES orthogonalization failed, linear solver diverged.
------------------------------ Error Exit -------------------------------
I changed my configure for several time and could only change the step number where it stopped. So I wonder if the error came from my wrong settings or I have reached the limitation of the code now.
I would be appreciated for any help, thank you for your reading.
Best wishes;
Shihe Jia
ShiheJia is offline   Reply With Quote
Shape optimizing the tunnel case with energy on zyao1 FLUENT 0 December 1, 2020 16:05
MRFSimpleFoam wind turbine case continuity error ysh1227 OpenFOAM Running, Solving & CFD 1 August 16, 2016 10:25
Is Playstation 3 cluster suitable for CFD work hsieh OpenFOAM 9 August 16, 2015 15:53
MRFSimpleFoam wind turbine case diverges ysh1227 OpenFOAM Running, Solving & CFD 2 May 7, 2015 11:13
Transient case running with a super computer microfin FLUENT 0 March 31, 2009 12:20
