Difference of Microsoft MPI and "parallel_computation.py" code |
Rep Power: 10 ![]() |
Hello
I am planning to conduct parallel simulations with SU2. As explained in SU2 website, I downloaded the Microsoft MPI and used the command "mpiexec -n NP SU2_CFD name.cfg" for parallel computation. It used the "parMETIS" substructure in order to divide domain into groups for parallel computations. Then it worked well and conducted a simulation faster than sequential one. However, there is another python code in SU2 called "parallel_computation.py". What is this code for? If we have ability of Microsoft MPI, then, is this python code is necessary/unnecessary for parallel computations? Is it valid for earlier versions of SU2 only? I am a bit confused about that issue . Kindly regards |
Pedro Gomes
Rep Power: 13 ![]() |
That script was for convenience in the days when you needed to run SU2_SOL after SU2_CFD to get post processing files, and it also tries to automate the task of determining which mpi launcher (mpirun mpiexec) should be used.
In summary, you don't need it. |
mpi, node, parallel, processor |
Fortran->Assembly : How to remove redundant non-vectorized code? | aerosayan | Main CFD Forum | 6 | November 20, 2020 05:37 |
the code difference | Yanming Ding | OpenFOAM | 2 | June 5, 2013 04:44 |
finite difference code | esikhatar | Main CFD Forum | 0 | April 9, 2011 14:05 |
Design Integration with CFD? | John C. Chien | Main CFD Forum | 19 | May 17, 2001 15:56 |
What is the Better Way to Do CFD? | John C. Chien | Main CFD Forum | 54 | April 23, 2001 08:10 |
