Home > Forums > Software User Forums > SU2
Is it normal for an unsteady simulation to appear steady initially?
Old   November 27, 2020, 13:02
Question Is it normal for an unsteady simulation to appear steady initially?
Bradley Craig
Creg is on a distinguished road
As the title says.
I am running a 2D turbulent, unsteady simulation of a simple cylinder as a test case using a 2nd order dual time stepping method and after a large number of iterations in the problem doesnt seem to be dispaying any unsteady flow characteristics.
Is this transient behaviour to be expected initially?
Thanks in advance
Creg is offline   Reply With Quote
Old   November 28, 2020, 12:20
pcg
Pedro Gomes
pcg is on a distinguished road
What unsteady phenomena are you expecting to capture?
You will not see turbulence eddies with a URANS simulation...
Another possibility is that your timestep is too large for what you are simulating (vortex shedding?) and so everything get's damped.
pcg is offline   Reply With Quote
Old   November 28, 2020, 14:33
Post
Bradley Craig
I was expecting to see vortex shredding, but instead i just obtain a fully developed, constant wake behind the cylinder.
I will try decreasing the timestep to see if this will show signs of vortexes.
Thank you
cylinder, structured mesh., unsteady flow, urans
Fan simulation with inlet and outlet duct for finding fan curve chaudhry_hashim FLUENT 0 August 6, 2014 11:49
Unsteady Fan Simulation Time step rvl565 Main CFD Forum 0 June 13, 2014 01:14
Fan flow simulation in open air idiroft CFX 5 June 10, 2014 08:34
[snappyHexMesh] determining displacement for added points CFDnewbie147 OpenFOAM Meshing & Mesh Conversion 1 October 22, 2013 10:53
conversion steady to unsteady Clementhuon Siemens 7 January 26, 2012 05:33
