Avijeet
Rep Power: 14 ![]() |
I've gone through most of the test cases available for dynamic mesh in SU2. I'm not able to understand from those examples whether SU2 has dynamic remeshing capabilities. Ofcourse there are examples of rotating bodies, where some part of the existing mesh is rotating. But is it possible to execute a simulation where, let's say, a wing is moving through air (instead of air moving over the wing), with a steady translation rate, which means the wall will move forward in the mesh, requiring dynamic remeshing to create/fill up holes.
Any help will be greatly appreciated. |
Pedro Gomes
There is no dynamic remeshing in SU2.
Also there are no overset meshes. There is steady state translation or rotation of entire domains, and mesh deformation for when some boundaries move but not others. Both are covered in the examples in the TestCases folders. |
Avijeet
Thanks pcg for clarifying. Just had one more question, if let's say I gave moving wall condition to my wing surface, with the speed set to whatever mach number want to carry out the study at, and the wall is set to a no-slip wall in a RANS solver, will that work properly?
Pedro Gomes
It depends what you consider work properly, would the solver converge? maybe. Would it be physical? Probably not.
If you want to simulate steady state flow around a moving thing, you need some kind of infinitely repeating motion. For example the lid-driven cavity problem where one of the surfaces is given a velocity, you can imagine that surface is one side of a belt going past again and again. Another example is a cylinder spining around its axis, no matter at what point in time you look at the cylinder, you see the same thing, i.e. the same surface velocities and the cylinder in the same place. |
Avijeet
You're right. I wanted to know if the case thus defined would solve for the correct physics problem. Now I understand that I need to approach it differently. Thanks for taking the time out to answer with examples.
dynamic mesh;, grid movement;, remeshing |
Ship resistance shows wiggles when using Overset mesh and dynamic mesh in Fluent | Qingsong | FLUENT | 2 | March 21, 2022 16:08 |
sliding mesh problem in CFX | Saima | CFX | 46 | September 11, 2021 08:38 |
[ICEM] Dynamic mesh setup with ICEM | David121284 | ANSYS Meshing & Geometry | 0 | April 11, 2014 05:19 |
Dynamic Mesh "Shadow Wall" | thezack | FLUENT | 0 | June 4, 2013 23:09 |
dynamic mesh for drop interface | IndrajitW | FLUENT | 0 | March 30, 2013 09:03 |
