Avijeet
Rep Power: 13 ![]() |
I was using SU2 to run some simulations on the ONERA M6 wing. The standard transonic test case (M~=0.84) converged fairly quickly and produced results that were well in agreement with the validation results.
Problem occurred when I tried to simulate a low subsonic flow (M=0.25) over the same wing. SU2 won't converge no matter how low I set the CFL. I wanted to ask are there any known issues with SU2 at low mach numbers for 3D flows? Few details regarding my simulation: Solver = RANS, SA turbulence model 0.25 Mach, Compressible flow |
Amit
I would recommend you to try -
CONV_NUM_METHOD_FLOW= AUSMPLUSUP or SLAU. Switch off the multigrid if it is on - MGLEVEL= 0 Also add - USE_ACCURATE_FLUX_JACOBIANS= YES You can try constant CFL initially (5, 10 or whatever works) and see if it goes through...... |
case setup, divergence issue, subsonic flow |
Question about "Motion Mach Number" in "Dynamic Mesh Definition" SU2 version3 | JinZhiyi | SU2 | 3 | March 4, 2022 00:27 |
Development of a Low mach PISO solver | nishant_hull | OpenFOAM Programming & Development | 0 | August 25, 2009 12:48 |
CFX for low subsonic regime | sa | CFX | 2 | January 12, 2009 07:36 |
non-dimensional analysis in Fluent | Endee | FLUENT | 8 | September 7, 2005 16:16 |
Inviscid Drag at subsonic, subcritical Mach # | Axel Rohde | Main CFD Forum | 1 | November 19, 2001 12:19 |
