November 19, 2020, 08:39 |
Error: CSysSolve linear solver diverged
Hello everybody, I am trying to run a turbulent simulation with RANS solver and the same error keeps showing up:
Error in "void CSysSolve<ScalarType>::ModGramSchmidt(int, su2matrix<ScalarType>&, std::vector<CSysVector<ScalarType> >&) const [with ScalarType = double; su2matrix<ScalarType> = C2DContainer<long unsigned int, double, (StorageType)0, 64, 0, 0>] FGRMES orthogonalization failed, linear solver diverged I have already tried to change the CFL number, the slope limiter, the type of linear solver, convergence criteria and all the other parameters, but nothing works. Does anyone have an idea of what might be happening here? Thanks in advanced |
November 29, 2020, 00:43 |
Amit
Rep Power: 13 |
Is it happening at the start or after few iterations ?
Make sure that your mesh is of acceptable quality and boundary conditions are correctly applied (at times mesh quality causes such divergence issue). Having said that, give a try to - LINEAR_SOLVER= BCGSTAB LINEAR_SOLVER_PREC= ILU LINEAR_SOLVER_ITER= 5 or 10 (if needed) (In one case, these setting helped me to overcome the similar issue) You can also try first order simulation followed by second order (restart from first) and see if it helps. Also switch off the multigrid (if turned on). |
foam-extend-4.1 release | hjasak | OpenFOAM Announcements from Other Sources | 19 | July 16, 2021 06:02 |
[ANSYS Meshing] Help with element size | sandri_92 | ANSYS Meshing & Geometry | 14 | November 14, 2018 08:54 |
Star cd es-ice solver error | ernarasimman | STAR-CD | 2 | September 12, 2014 01:01 |
A turbulent test case for rhoCentralFoam | immortality | OpenFOAM Running, Solving & CFD | 13 | April 20, 2014 07:32 |
how to modify fvScheme to converge? | immortality | OpenFOAM Running, Solving & CFD | 15 | January 16, 2013 14:06 |
