November 12, 2020, 08:04 |
Problem with SU2 format mesh
china
Rep Power: 5 |
I tried to run a 3D simulation using SU2. Meshes were generated using Pointwise. When the mesh was of 2322425 volume element, calculation was sucessful. However when the cell number was 5081094, SU2 failed with following information: ------------------------------------------------- Executing the partitioning functions. Building the graph adjacency structure. Calling ParMETIS... graph partitioning complete (176335 edge cuts). Distributing ParMETIS coloring. [PowerEdge-T640:14361] *** Process received signal *** [PowerEdge-T640:14361] Signal: Segmentation fault (11) [PowerEdge-T640:14361] Signal code: Address not mapped (1) [PowerEdge-T640:14361] Failing at address: 0x4a85a [PowerEdge-T640:14361] [ 0] /lib/x86_64-linux-gnu/libpthread.so.0(+0x128a0)[0x7fa083d548a0] [PowerEdge-T640:14361] [ 1] SU2_CFD(+0x6cb4f9)[0x55b8756854f9] [PowerEdge-T640:14361] [ 2] SU2_CFD(+0x6ccb5c)[0x55b875686b5c] [PowerEdge-T640:14361] [ 3] SU2_CFD(+0x13f81f)[0x55b8750f981f] [PowerEdge-T640:14361] [ 4] SU2_CFD(+0x140726)[0x55b8750fa726] [PowerEdge-T640:14361] [ 5] SU2_CFD(+0x140f8e)[0x55b8750faf8e] [PowerEdge-T640:14361] [ 6] SU2_CFD(+0x11d89f)[0x55b8750d789f] [PowerEdge-T640:14361] [ 7] SU2_CFD(+0xd700f)[0x55b87509100f] [PowerEdge-T640:14361] [ 8] /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xe7)[0x7fa082cffb97] [PowerEdge-T640:14361] [ 9] SU2_CFD(+0xefd2a)[0x55b8750a9d2a] [PowerEdge-T640:14361] *** End of error message *** ------------------------------------------------- Is there a limit for the cell number in SU2? Or anything else wrong. Thanks in advance. Best regards, |
mesh |
Salome cgns format mesh to SU2 | JPBLourenco | SU2 | 19 | November 18, 2019 02:11 |
[snappyHexMesh] snappyHexMesh does not create any mesh except one for the reference cell | Arman_N | OpenFOAM Meshing & Mesh Conversion | 1 | May 20, 2019 17:16 |
Mesh Boundary Assignment Question | Wandadars | Mesh Generation & Pre-Processing | 1 | June 13, 2016 17:19 |
[ICEM] Problem with using the Delaunay volume mesh method | manahara | ANSYS Meshing & Geometry | 12 | December 25, 2014 21:54 |
3D Hybrid Mesh Errors | DarrenC | ANSYS Meshing & Geometry | 11 | August 5, 2013 06:42 |
