Home > Forums > Software User Forums > SU2
Using Machine Learning scripts in SU2
Old   November 11, 2020, 09:27
Default Using Machine Learning scripts in SU2
Shaoze
sminder is on a distinguished road
I'm trying to combine machine learning with fluid mechanics. SU2 seems to be a good start as it supports python. One of my questions is how can I change the boundary conditions with my own script? For example, if I use a neural network to adjust the boundary conditions, how can I integrate a custom python script to define a dynamic boundary condition in SU2, is it feasible and how hard it is?
Many thanks!
Li
sminder is offline   Reply With Quote
Old   November 13, 2020, 03:03
Wally Maier
wallym is on a distinguished road
Hi Li,
Thanks for your post! Since the boundary conditions are defined in the configure script, you should be able to have a simple function that reads the configure file, replaces/writes the boundary conditions, and either runs/restarts SU2.
While Im sure there are other ways to do this more efficiently, this should work and be relatively easy.
wallym is offline   Reply With Quote
Old   November 13, 2020, 06:42
Shaoze
Originally Posted by wallym View Post
Hi Li,
Thank you for your reply, I wonder is there a function that I can update the boundary conditions without reading the file? As I have to change the boundary condition every time step. For example, can I just update the variable like "configure.MACH_NUMBER=XX"?
Many thanks,
Li
Old   February 26, 2021, 03:12
Default Machine learning for CFD
CFD Lab
CFD Lab is on a distinguished road
Good day, I am looking for a comprehensive course in which I can learn, How to implement Machine Learning with Computational Fluid Dynamics. I am also looking for some research Ideas. Looking for a kind response thanks
CFD Lab is offline   Reply With Quote
[TUTORIAL] Run fluent on distributed memory with 2 windows 7 64 bit machines ghost82 FLUENT 54 February 9, 2022 04:32
machine learning algorithms Rajesh Sundaram hsejarm Main CFD Forum 4 February 26, 2021 03:16
Machine learning in fluid dynamics harsha_kulkarni Main CFD Forum 1 September 15, 2020 06:00
SU2 for machine learning Selvakumar SU2 1 July 20, 2019 04:25
Introducing SU2 International Developers Society (IDS) fpalacios SU2 News & Announcements 1 June 17, 2019 23:38
