Home > Forums > Software User Forums > SU2
Incompressible blood flow simulation inside a 3D curved pipe
Old   October 30, 2020, 14:53
Default Incompressible blood flow simulation inside a 3D curved pipe
semions is on a distinguished road
I'm trying to simulate blood flowing inside an irregularly shaped 3D vessel with one inlet and one outlet. The inlet is not normal to x, y or z. For now, I'm running steady state simulations.
I'm using SU2 v 7.0.2 and I started by editing the cfg file from a 2D channel example. In my case, I'm prescribing the an inlet velocity profile from a file.
I'm reaching convergence in a few iterations, but I'm not convinced by the results. In particular, I don't understand:
- why the INC_VELOCITY_INIT value will affect the computed velocity field so much,
- how to properly set the CFL number,
- why the velocity profile doesn't seem to fully develop to a parabolic-like profile,
- if there is a way to strongly impose the inlet boundary condition.
Many thanks.
semions is offline   Reply With Quote
Old   October 31, 2020, 18:11
pcg
Pedro Gomes
pcg is on a distinguished road
You have INNER_ITER set to 20, your case cannot possibly be converged.
I guess that is why you see a dependence on initial conditions and no parabolic profile.
Increase INNER_ITER to a large number, say 10000, and monitor the residuals and some post processing metric like drag. For a simple problem you want at least 6 orders of magnitude drop in residuals and the value of drag to be the same for a significant number of iterations.
CFL for steady state problems acts as a form of under relaxation. For a laminar problem you should be able to use a large value 1000 or more.
With very low values your case will never converge.
With very large values the solver will become unstable.
pcg is offline   Reply With Quote
Old   November 4, 2020, 06:43
Thanks for the advice.
I increased INNER_ITER and I tried different combinations of CFL number and linear solvers.
I can't make my simulation converge. The residuals start from -6 and if CFL > 10, the residuals increase and the simulation eventually diverges; if CFD < 10, the residuals won't go below the initial orders of magnitude even after a few thousand iterations.
I wonder if there's something that I'm missing, since I've run this kind of simulation many time with openfoam and it converges in a few minutes.
Thanks again.
Old   November 4, 2020, 11:13
Akshay Koodly
akoodlyr is on a distinguished road
If possible could you share the mesh file?
Also, can you try the simulation by setting the INC_NONDIM to INITIAL_VALUES instead of DIMENSIONAL and see if you notice a difference? I know in theory there shouldn't be, but I have noticed some weird convergence behavior when using dimensional simulations with very large values for density or velocity.
Cheers
akoodlyr is offline   Reply With Quote
Old   November 5, 2020, 10:34
Unfortunately, my mesh is too large (approx. 98 MB) and CFD online won't let me upload such a file.
Old   November 6, 2020, 07:41
Akshay Koodly
Ok, no problem.
Did you have any progress by changing the non-dimensionalisation?
Old   November 6, 2020, 08:47
No, no noticeable change in the residuals.
blood flow, incompressible flow, irregular domain
Turbulent air flow through curved pipe - no vorticity maike151 OpenFOAM Running, Solving & CFD 3 April 28, 2020 09:29
Pressure drop in pipe flow with Large Eddy Simulation xerox FLUENT 1 October 16, 2019 09:55
Error in mass flow rates in inlet region of pipe during pipe flow simulation fluent_user121 CFX 1 September 22, 2019 15:04
Simulation of Blood Flow sathwik718 STAR-CCM+ 30 May 21, 2014 15:18
simulation of blood flow Hoffenheim Main CFD Forum 0 May 24, 2012 17:12
