October 24, 2020, 15:10 |
trouble running SU2 mesh made in gmsh
Hernán David Cogollo
Rep Power: 6 |
Hi to everyone.
I'm trying to running a airfoil case, I made the grid in Gmsh but I made it structured, this grid has 4 parts and when I run the case in SU2 never converge, and the results the CD and CL are very unusual. I would like know what is the problem, for the size of the file I attached the a url of these. https://drive.google.com/drive/folde...5a?usp=sharing |
November 29, 2020, 00:00 |
Amit
Rep Power: 13 |
Hmmmm.... I saw your .cfg file, plenty of changes are needed.....
First clarification required - You have used REYNOLDS_LENGTH= 100 and REYNOLDS_NUMBER= 4E6. Is this input correct? Also the flow you are simulating is Laminar or turbulent? I will suggest you the changes in .cfg file, followed by above clarifications. |
SU2_CFD 3d euler not converge mine gmsh mesh | lpustin | SU2 | 2 | December 3, 2017 13:43 |
Gmsh mesh to SU2 error : "corrupted size vs. prev_size" | Cmac22 | SU2 | 10 | August 9, 2017 12:19 |
[snappyHexMesh] No layers in a small gap | bobburnquist | OpenFOAM Meshing & Mesh Conversion | 6 | August 26, 2015 09:38 |
[snappyHexMesh] Layers:problem with curvature | giulio.topazio | OpenFOAM Meshing & Mesh Conversion | 10 | August 22, 2012 09:03 |
[Gmsh] gmshToFoam problem: not the same mesh in Gmsh vs. paraview | zhernadi | OpenFOAM Meshing & Mesh Conversion | 8 | July 7, 2011 02:28 |
