September 29, 2020, 12:03 |
getting files suitable for TECPLOT
Rep Power: 6 |
Hi Folks,
Hope all are doing well. I just have a confusion regarding the file formats that is suitable for TECPLOT. Previously, I had set the tabular format to PARAVIEW and I was able to post-process using PARAVIEW (SU2 generated .vtk files). However, .vtk files are not supported by TECPLOT. Can anyone assist me in what changes I have to make in the configuration file for SU2 so that I can get surface_flow and flow file formats compatible with TECPLOT? Is there a way to generate .plt file from SU2? Thanks. |
October 19, 2020, 12:55 |
Wally Maier
Rep Power: 7 |
Thanks for your post, and sorry for the delay in response. You can set the output files to Tecplot using these options: % % Output tabular file format (TECPLOT, CSV) TABULAR_FORMAT= TECPLOT % % Files to output % Possible formats : (TECPLOT, TECPLOT_BINARY, SURFACE_TECPLOT, % SURFACE_TECPLOT_BINARY, CSV, SURFACE_CSV, PARAVIEW, PARAVIEW_BINARY, SURFACE_PARAVIEW, % SURFACE_PARAVIEW_BINARY, MESH, RESTART_BINARY, RESTART_ASCII, CGNS, STL) % default : (RESTART, PARAVIEW, SURFACE_PARAVIEW) OUTPUT_FILES= (RESTART, PARAVIEW, SURFACE_PARAVIEW) % |
[Gmsh] Meshing 3D volume from STL/STEP Files (Gmsh) | jgross | OpenFOAM Meshing & Mesh Conversion | 6 | July 15, 2022 06:11 |
How to convert .trn files to .cgns files | cyln | CFX | 5 | October 21, 2018 00:25 |
UDF help for Rapid compression machine ECM. | sanjeetlimbu | Fluent UDF and Scheme Programming | 0 | March 17, 2015 23:45 |
Problems in compiling paraview in Suse 10.3 platform | chiven | OpenFOAM Installation | 3 | December 1, 2009 08:21 |
OpenFOAM15 paraFoam bug | koen | OpenFOAM Bugs | 19 | June 30, 2009 11:46 |
