September 28, 2020, 14:16 |
Problem with 3D Boundary layer using gmsh
federico ghidini
Good morning,
I'm trying to create a 3D model of a rotor using gmsh. If I try to create a normal 3d mesh using default values of mesh characteristics it works fine, but if I try to use the boundary layer field it gives me an error(No element in volume 1) I attach the two .geo files: the first without boundary layer(works perfectly), the secpnd with boundary layer(doesn't work) I'm a beginner with gmsh so feel free to tell me correction of any sort. Thanks!! mesh_10_1.txt mesh_10_2.txt |
May 27, 2021, 00:26 |
Pedro Coimbra
Rep Power: 5 |
Did you manage to fix it?
3d boundary layer, gmsh boundary layer |
y+ = 1 boundary layer mesh with snappyHexMesh | Arzed23 | OpenFOAM Running, Solving & CFD | 6 | November 23, 2022 16:15 |
Error - Solar absorber - Solar Thermal Radiation | MichaelK | CFX | 12 | September 1, 2016 06:15 |
Wrong flow in ratating domain problem | Sanyo | CFX | 17 | August 15, 2015 07:20 |
Low Mixing time Problem | Mavier | CFX | 5 | April 29, 2013 01:00 |
[snappyHexMesh] Boundary layer generation problems | ivan_cozza | OpenFOAM Meshing & Mesh Conversion | 0 | October 6, 2010 14:47 |
