Home > Forums > Software User Forums > SU2
Not printing solution files
Old   September 11, 2020, 08:41
Default Not printing solution files
Dr. H.K. Narahari
hk.narahari is on a distinguished road
I use PARAVIEW to visualize results, and I am facing a peculiar problem in that neither paraview files nor solution files are not being written. However, the execution proceeds as expected..
I have made many simulations using SU2 and never had this issue. I am unable to locate the error. Any pointer/ help would be gladly accepted. I am attaching the CFG file
Narahari
hk.narahari is offline   Reply With Quote
Old   September 11, 2020, 14:59
pcg
Pedro Gomes
pcg is on a distinguished road
Please post the screen output of SU2.
What version are you using? 7.0.3 like it says in the file?
pcg is offline   Reply With Quote
Old   September 12, 2020, 01:44
Default Not printing files
Dr. H.K. Narahari
I am using version 7.06 (just forgot to change in the config file) I am attaching the screen shot as well. Thanks for looking into the issue
Regards
Narahari
Old   September 12, 2020, 11:39
pcg
Pedro Gomes
That does not show enough information, copy paste the entire output please.
Old   September 13, 2020, 13:21
Dr. H.K. Narahari
I ran the code for 50 iterations as before intermediate results are nor being written, but the solution files are written ONLY after completion of max number of iterations. This can be a problem if the solution takes 500-700 iterations.
In addition, PARAVIEW throws an error reading the .VTU files with a message about offset, I guess .VTK files would be better.
I am attaching the full printout for clarity.
Regards
Narahari
Old   September 13, 2020, 17:21
pcg
Pedro Gomes
The option to write output files at smaller intervals is OUTPUT_WRT_FREQ (since v7.0.0).
There is a problem with the vtu output on Windows on versions 7.0.4/5/6, workarounds are given here: Problem opening vtu-file in Paraview
2way FSi, Initialize with steady solution, Fluent, Transient Sturcural, System Coupli mmkkeshavarzi FLUENT 1 June 28, 2024 08:03
Saving Transient solution data files Aijiazi FLUENT 8 September 7, 2020 05:49
Results saving in CFD hawk Main CFD Forum 16 July 21, 2005 21:51
[making animations] fclose fails to close files? Mika FLUENT 0 March 30, 2001 09:19
Wall functions Abhijit Tilak Main CFD Forum 6 February 5, 1999 02:16
